Clear Pass Syslog - TACACS Auth Login Failures
  • 1.  Clear Pass Syslog - TACACS Auth Login Failures
    Posted Aug 25, 2023 06:08 AM
    I have been playing around with the syslogs in Clear Pass and have successfully set up our syslog server to receive TACACs logs. We are particularly interested in failed login attempts to our network devices and would like to see these come across. They seem to come across fine, but the log doesn't show much info in the syslog itself (only the username that attempted and that it was a failed attempt), it doesn't show where it came from or what it was trying to access. It includes the session ID which is something, so at least we can look this up in Clear Pass, but it would be nice to see a fuller log. Does anyone know if this is this something that can be achieved? - It's currently set to 'Warnings', but I have also tried 'informational'.
    Thanks.
  • 2.  RE: Clear Pass Syslog - TACACS Auth Login Failures
    Posted Aug 25, 2023 07:02 AM
    Did you find the option for Syslog Export Filters? That allows you to send authentication/audit logs to a syslog server with configurable columns:
  • 3.  RE: Clear Pass Syslog - TACACS Auth Login Failures
    Posted Aug 25, 2023 07:21 AM
    Thanks for the reply. I tired working in there originally and nothing was coming through, so I enabled it here (see below):
    That works now, but gives me the limited info.
  • 4.  RE: Clear Pass Syslog - TACACS Auth Login Failures
    Posted Sep 04, 2023 04:20 AM
    Yes, that is expected as these are process logs, not authentication/accounting logs. These are different logs.
    For more detailed authentication information like usernames, you need to create syslog servers and syslog filters. If that doesn't work, try to find out why that doesn't work. Your Aruba partner or Aruba Support may be able to assist in that.
