Clear/cleanup Social Logins from Clearpass?
  • 1.  Clear/cleanup Social Logins from Clearpass?
    Posted Nov 07, 2018 04:48 AM
    Hi.
    How do I cleanup the logs (all the logs/knowledge of) social logins from Clearpass from lets say 14 days back and older?
    From what I understand the Access Tracker have a default retention setting of 7 days. However I can still see references to social logins by browsing "Endpoint Profiler". If I click a MAC address that is known I can even see the social login user name.
    Petter
  • 2.  RE: Clear/cleanup Social Logins from Clearpass?
    Posted Nov 07, 2018 04:59 AM
    Question:
    Are you using cleanup intervals to remove your endpoints and are still seeing the information about those endpoints in profiler?  https://www.arubanetworks.com/techdocs/ClearPass/6.7/PolicyManager/index.htm#CPPM_UserGuide/Admin/ServerConfig_clusterwideparams.htm#Cleanup
  • 3.  RE: Clear/cleanup Social Logins from Clearpass?
    Posted Nov 07, 2018 05:11 AM
    All my Cleanup Intervals settings are set to the default values. I can see that there is no cleanup of profiled clients. Will try to setup some good values.
    Thank you.
  • 4.  RE: Clear/cleanup Social Logins from Clearpass?
    Posted Nov 07, 2018 05:37 AM
    You can also optionally do a manual Cleanup so that you are not waiting for 1am for your endpoints to be purged:  https://www.arubanetworks.com/techdocs/ClearPass/6.7/PolicyManager/index.htm#CPPM_UserGuide/Admin/ServerConfig_cleanup.htm?Highlight=cleanup
