Clearing CPPM endpoints
  • 1.  Clearing CPPM endpoints
    Posted Dec 20, 2012 10:00 AM
    Anyone know if there's a way to bulk-delete endpoints ( even deleting all endpoints would be fine)  in CPPM
    ( i.e: other than 100 at a time)
  • 2.  RE: Clearing CPPM endpoints
    Posted Dec 20, 2012 12:26 PM
    You can use the cluster reset-database command from the CLI – this will wipe out other configuration settings though, unfortunately.
  • 3.  RE: Clearing CPPM endpoints
    Posted Feb 01, 2013 03:06 PM
    The following setting may also be useful. In the Cluster-Wide Parameters (which is under Administration, Server Manager, Server Configuration), you can set cleanup intervals for unknown and for known/disabled endpoints that have not been used for the configured time:
  • 4.  RE: Clearing CPPM endpoints
    Posted Mar 26, 2015 10:42 AM
    the change of cluster wide parameters delete Endpoint entries wich was stored in the past or does it only work for newly created endpoints?
