Clearpas Guest : Role name
  • 1.  Clearpas Guest : Role name
    Posted Jul 16, 2018 07:55 AM
    I would like to create devices in Clearpass Guest but it doesn't work.
    The form is strange, I can't select role_name. I have tried to displayed it, but it is empty.
    When I validate there is an error beacause role_name is required. "
    Have you ever seen this problem?
    "unable to determine the role ID"
    Thanks for your help,
  • 2.  RE: Clearpas Guest : Role name
    Posted Jul 16, 2018 08:11 AM
    Are you using the default mac_create page?
  • 3.  RE: Clearpas Guest : Role name
    Posted Jul 17, 2018 03:31 AM
    Hi tim,
    Yes I'm using it.
  • 4.  RE: Clearpas Guest : Role name
    Posted Jul 17, 2018 04:02 AM
    An other element, maybe my probleme will be more clear.
    On other form, contractor configure role_id to 2 automatically.
    But there is no correspondance between role_name and role_id as you can see on the screenshot.
    I have tried to configure "role mapping" in CCPM but it doesn't work (screenshot)
    Is it the same database?
  • 5.  RE: Clearpas Guest : Role name
    Posted Jul 25, 2018 03:39 AM
    When using default set-up there is a role mapping policy created called [Guest Roles].
    Modify this to include the role IDs and names you require and then reference the appropriate role ID in the mac_create form.
  • 6.  RE: Clearpas Guest : Role name
    Posted Jul 25, 2018 04:02 AM
    Thanks for your help!
