ClearPass .1x Agent
  • 1.  ClearPass .1x Agent
    Posted Nov 23, 2013 02:39 AM
    I'm confused about difference between   Persistent Agent & Dissolvable Agent
    is this software to be installed on PC ? what is the difference ?
  • 2.  RE: ClearPass .1x Agent
    Posted Nov 23, 2013 03:05 AM
    The Persistent agent is installed on a PC and runs constantly.  The dissolvable agent runs as a java applet and only runs in a web page.
  • 3.  RE: ClearPass .1x Agent
    Posted Nov 23, 2013 04:29 PM
    Is Persistent Agent a   ".1x"  agent ?  or it is just health monitoring agent ?
    Can i use it for  ".1x" authentication instead of windows   builtin ".1x"
  • 4.  RE: ClearPass .1x Agent
    Posted Nov 23, 2013 04:47 PM
    The agent is for health/posture. The built in NAP feature in Windows can
    be used as well.
  • 5.  RE: ClearPass .1x Agent
    Posted Nov 23, 2013 04:52 PM
    It is only a health and posture monitoring agent.  It does not do 802.1x, and you cannot use it for 802.1x authentication.
    Please take a look at the CPPM 6.2 User Guide here:  http://support.arubanetworks.com/DOCUMENTATION/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=11862 at Chapter 10, posture for more answers about the Onguard Agent.
  • 6.  RE: ClearPass .1x Agent
    Posted Nov 24, 2013 09:59 AM
    Thx aruba doesn't have .1x Agent ?
  • 7.  RE: ClearPass .1x Agent
    Posted Nov 24, 2013 10:10 AM
    Aruba does not have a 802.1x agent.
    The question is, what are you trying to accomplish with a 802.1x agent?
  • 8.  RE: ClearPass .1x Agent
    Posted Nov 24, 2013 04:40 PM
    Thx
    as other vendors claims to have mopre advanced options when using their own .1x Agent like re-auth interval ,...
  • 9.  RE: ClearPass .1x Agent
    Posted Nov 24, 2013 07:28 PM
    Reauth interval is a function of radius, not the agent. You do not want to have to install an agent on all of your devices, trust me. On guard is for NAC that cannot be done outside of standard radius.
  • 10.  RE: ClearPass .1x Agent
