Clearpass 500 to clearpass 5000
  • 1.  Clearpass 500 to clearpass 5000
    Posted Feb 12, 2016 02:57 PM
    Hello
    If i got a clearpass 500
    And let say the requriement change from 400 devices to 2000 devices per day for clearpass guest
    it is possible to upgrade the clearpass 500 to a clearpass 5000 ?
    Or you have to buy a clearpass 5000 and add it as a subcriber?
    Or which is the best option?
    Cheers
    Carlos
  • 2.  RE: Clearpass 500 to clearpass 5000
    Posted Feb 12, 2016 02:59 PM
    You would need to buy a CP-5K. You always want to use the bigger box as the publisher (outside of initial setup).
  • 3.  RE: Clearpass 500 to clearpass 5000
    Posted Feb 15, 2016 09:33 AM
    Thank you Tim
    I just wanted to confirm that.
    Cheers
    Carlos
  • 4.  RE: Clearpass 500 to clearpass 5000
    Posted Feb 15, 2016 09:53 AM
    I assume the simplest way to achieve this would be to add the CPPM 5K as a standby publisher then initiate a failover?
  • 5.  RE: Clearpass 500 to clearpass 5000
    Posted Feb 15, 2016 10:12 AM
    Exactly
