last person joined: 9 hours ago
Clearpass 6.10.0 DUR
This thread has been viewed 47 times
  • 1.  Clearpass 6.10.0 DUR
    Posted Jun 04, 2021 03:40 PM
    Hello, I would like to try out the downloadable user roles feature with an IAP in my test environment. Unfortunately the certificate cant be downloaded from the clearpass server. When i try to download the cert manually "http://<clearpass- fqdn>/.well-known/aruba/clearpass/https-root.pem" the server rsponse with an 404 error.... any idea?
    Martin Gerstendorf
  • 2.  RE: Clearpass 6.10.0 DUR
    Posted Jun 05, 2021 05:02 AM
    I see the same here in my lab. Please open a case with Aruba Support to get this fixed.
  • 3.  RE: Clearpass 6.10.0 DUR
    Posted Jun 10, 2021 01:14 PM
    One of my customer had the same issue, TAC found out it's a bug in Clearpass 6.10.0, it fails to download the root-certificate to the switch.
    As a workaround, you can manually add the root-ca cert file to the switch using following commands:
    crypto pki ta-profile CLEARPASS
    copy tftp ta-certificate CLEARPASS tftp-server <cert-file-name>
    Greetings Johannes
    Johannes Haberstroh
  • 4.  RE: Clearpass 6.10.0 DUR
    Posted Jun 10, 2021 03:02 PM
    Thanks, i did a downgrade to 6.9.6 … Now ist works
    Martin Gerstendorf
