ClearPass 6.11 - Intune V4 extension
  • 1.  ClearPass 6.11 - Intune V4 extension
    Posted Nov 22, 2023 08:02 AM
    Hello all,
    A customer wants to upgrade their ClearPass to version 6.11, they are using the Intune V4 extension. Is this supported on 6.11?
    Jason
  • 2.  RE: ClearPass 6.11 - Intune V4 extension
    Posted Nov 22, 2023 05:43 PM
    I have not tried it myself  but with 6.11, you have the option to upgrade.
  • 3.  RE: ClearPass 6.11 - Intune V4 extension
    Posted Nov 26, 2023 03:26 PM
    Intune extension is in version 6 with a couple of updates and I suggest upgradering as v4 is quite old and v6 has several needed updates.
    6.11 support the latest extension versions.
    Note that v6 comes with a major change in terms of how the service is used to gather information, as it's no longer using real-time lookup in Azure Intune. If you need that then 6.11 support using Azure AD as authorization source..
    Take a look at the integration guide as Herman linked in that other post..
    https://support.hpe.com/hpesc/public/docDisplay?docId=a00112290en_us
    John-Egil Solberg |
    ACMX | ACCX
