That announcement may be on it's way as I see 6.12 posted on ASP as well... and the in product update check shows it as well:
But would definitely recommend to wait for the release announcement...
Original Message:
Sent: Dec 05, 2023 09:37 AM
Subject: Clearpass 6.12 AWS
Just a wild guess, but I think that someone made a misstake and the notice about the new version shouldn't have been send to all customers...
Best Regards
Jonas Hammarbäck
MVP 2023, ACCX #1335, ACX-Network Security, Aruba SME, ACMP, ACDP , ACEP, ACSA
Aranya AB
Original Message:
Sent: Dec 05, 2023 09:35 AM
yeah was suspecting the same.
But quiet annoying that my customers receive a lot of emails from AWS that 6.12 is there.
Where as we don't get any info what is changed or whatever.
Original Message:
Sent: Dec 05, 2023 09:23 AM
Hi
I have not seen any communication from Aruba regarding ClearPass 6.12 except that in some TAC cases where I have reported GUI glitches I got the feedback that it will be solved in version 6.12. But no estimated release date.
But with the past years releases of new major versions with 1-1,5 years between them version 6.12 should be around the corner.
But I should say that you can continue to run 6.11 for quite some time. 6.11 is also an LSR and thus version 6.12 may be an SSR.
Best Regards
Jonas Hammarbäck
Aranya AB
Original Message:
Sent: Dec 05, 2023 06:15 AM
Hey,
I'm running a clearpass 6.11 in AWS for one of our customer.
They received an email from the AWS store that 6.12 is available and is recommend to upgrade.
I found no info of this version in ASP or somewhere else.
None of my colleagues knows anything about 6.12 .
What are the improvements and is it necessary to upgrade to this version for cloud clearpass in AWS?
Or do someone else runs 6.12 already?
