ClearPass 6.3 and Cisco
  • 1.  ClearPass 6.3 and Cisco
    Posted Mar 19, 2014 04:00 PM
    I'm trying to setup ClearPass with my Cisco switches to do dot1x wired authentication.  I have a policy setup to push out a Quaratine VLAN and a dACL/URL Redirect.  The port on the Cisco switch will come up start going through authentication but I'll get "Authorization failed or unapplied for client".  If i do a show authentication session on the interface I'm trying with it shows "Status:  Authz Failed".  If I take out the url redirect the port comes up fine, but I'm using the url redirect for remediation so it's needed.  I've opened a TAC case with both Aruba and Cisco and both are scratching their heads.  I've followed every guide I could find from Aruba and Cisco on setting this up.  If anyone has suggestions or has run into this please let me know.  Thanks
  • 2.  RE: ClearPass 6.3 and Cisco
    Posted Mar 19, 2014 04:46 PM
    do you have the ip http server and ip http secure-server entries on the switch?
  • 3.  RE: ClearPass 6.3 and Cisco
    Posted Mar 19, 2014 04:47 PM
    Yes I have those commands on the switch.
  • 4.  RE: ClearPass 6.3 and Cisco
    Posted Mar 19, 2014 04:56 PM
    What version of Cisco IOS are you running?
  • 5.  RE: ClearPass 6.3 and Cisco
    Posted Mar 19, 2014 05:05 PM
    I've tried a few different versions and hardware platforms.  Currently I'm working on a 3560G with 15.0(2)SE5.  I started with 12.2(58)SE2
  • 6.  RE: ClearPass 6.3 and Cisco
    Posted Mar 19, 2014 05:12 PM
    The only other thing aside from IOS version (versions seem to be very finiky) would be to check to see if you have a default port ACL on the port?
  • 7.  RE: ClearPass 6.3 and Cisco
    Posted Mar 19, 2014 05:16 PM
    I have an ACL called "temp" created and applied.  The acl is  permit ip any any.
  • 8.  RE: ClearPass 6.3 and Cisco
    Posted Mar 19, 2014 08:46 PM
    At which part of 802.1X are you getting this? Is it a dot1x failure or a MAB failure?
  • 9.  RE: ClearPass 6.3 and Cisco
    Posted Mar 19, 2014 09:09 PM
    So what happens is a port comes online dot1x checks for a computer cert, it passes, then we are using onguard as well so it does a posture check which comes back unhealthy since the user has not logged in yet.  ClearPass assigns a Quaratine VLAN and pushes out the dACL and url redirect.  MAB does not come into play.
  • 10.  RE: ClearPass 6.3 and Cisco
    Posted Mar 20, 2014 09:20 AM
    It sounds as though ClearPass is sending the proper response but the switch is not interpreting it properly for whatever reason.    Can you share the output of the following:
    - debug radius on the switch for that authenication connection.
    - the specific port configuration
    - show authentication sessions for that port/attempt
    I've seen similiar behavior in the past, but in those cases it was IOS version compatiblities or missing http server or default ACL commands.
  • 11.  RE: ClearPass 6.3 and Cisco
    Posted Mar 20, 2014 10:04 AM
    debug radiuson the switch for that authenication connection.
    - Attached txt file - radius_debug.txt
    interface GigabitEthernet0/5
     switchport access vlan 19
     switchport mode access
     ip access-group temp in
     authentication order dot1x mab
     authentication priority dot1x mab
     authentication port-control auto
     authentication periodic
     authentication timer reauthenticate server
     mab
     dot1x pae authenticator
     dot1x timeout server-timeout 30
     dot1x timeout tx-period 10
     dot1x max-req 3
     dot1x max-reauth-req 10
     spanning-tree portfast
    ord1-dc-NAC#sh authentication sessions int gi0/5
                Interface:  GigabitEthernet0/5
              MAC Address:  5c26.0a6c.9b3c
               IP Address:  10.145.10.150
                User-Name:  host/JGOULD-TEST.aspect.com
                   Domain:  DATA
          Security Policy:  Should Secure
          Security Status:  Unsecure
           Oper host mode:  single-host
         Oper control dir:  both
            Authorized By:  Authentication Server
              Vlan Policy:  N/A
          Session timeout:  10800s (server), Remaining: 10758s
           Timeout action:  Reauthenticate
             Idle timeout:  N/A
        Common Session ID:  0A9119080000014C1DA43B4F
          Acct Session ID:  0x0000016F
                   Handle:  0xA000014D
    Runnable methods list:
           Method   State
           dot1x    Authc Success
           mab      Not run
    Adding as attachements as well.
    Attachment(s)
    txt
    sh_auth_sess.txt   864 B 1 version
    txt
    Interface_config.txt   446 B 1 version
    txt
    Radius_Debug.txt   17 KB 1 version
  • 12.  RE: ClearPass 6.3 and Cisco
    Posted Mar 20, 2014 10:29 AM
    I see Cisco AVpair       [1]   92  "ACS:CiscoSecure-Defined-ACL=#ACSACL#-IP-Remediation_Portal_Cisco_dACL_and_Redirect-3005-98" being returned.       What is in this dACL?
  • 13.  RE: ClearPass 6.3 and Cisco
    Posted Mar 20, 2014 11:50 AM
    To update the thread; jgould56 and I worked on this.    By swapping the dACL with url-redirect-acl AVPair; referencing an ACL on the switch, the redirect functionality is working.
  • 14.  RE: ClearPass 6.3 and Cisco
    Posted Jul 17, 2014 04:20 PM
    The Cisco DACL must also always have a source of "any". The switch will convert this to the client IP. I was having trouble with DACL and as soon as I changed my ACL (i had just applied an exisiting one from a VLAN interface) - everything worked.
    Hope this helps someone.
