ClearPass 6.5 Virtual Appliance Partitioning
  • 1.  ClearPass 6.5 Virtual Appliance Partitioning
    Posted Jan 17, 2016 07:32 PM
    I've setup 2 ClearPass 5K virtual appliances with a 1TB disk added to each, however there is only ~500GB shown under system monitor for disk usage.
    As far as I understand a second partition should be created, but grub.conf only shows 1:
    title ClearPass Platform 6.5.4.76733 [Active]
    root (hd0,0)
    kernel /vmlinuz-3.10.0-123.20.1.aruba.x86_64 ro root=LABEL=/image1 rd_NO_LUKS KEYBOARDTYPE=pc KEYTABLE=us LANG=en_US.UTF-8 biosdevname=0 panic=30 console=tty0 rd_NO_MD SYSFONT=latarcyrheb-sun16 crashkernel=auto rd_NO_LVM rd_NO_DM fips=0 clocksource=tsc boot=/dev/sda1 divider=10 noapic nomodeset pcie_aspm=off
    initrd /initramfs-3.10.0-123.20.1.aruba.x86_64.img
    Does the second partition only get created during a major version upgrade?
  • 2.  RE: ClearPass 6.5 Virtual Appliance Partitioning
    Posted Jan 17, 2016 08:15 PM
    Yes Clearpass will create two partitions and one is for running and the second is for version upgrades.
  • 3.  RE: ClearPass 6.5 Virtual Appliance Partitioning
    Posted Jan 17, 2016 08:56 PM
    But the second partition will only be created during an upgrade?
  • 4.  RE: ClearPass 6.5 Virtual Appliance Partitioning
    Posted Jan 18, 2016 02:20 AM
    If you assigned 1TB then CentOS LVM will have created  2 x 500GB drives, the second is only used when you perform a major s/w upgrade.
