Clearpass 6.5.x SAP Afaria installation with IMEI with query
  • 1.  Clearpass 6.5.x SAP Afaria installation with IMEI with query
    Posted Mar 04, 2016 09:31 AM
    next step after certificate installation:
    SAP Afaria installation on clearpass.
    I know that i have to install SAP Afaria under Endpoint Context Servers.
    1. How can i check, if the configurations are correct and clearpass have connection to SAP Afaria ??
    2. what are the next steps ? I want that clearpass check on SAP Afaria if the IOS Phone is entitled to enter the corporate Network. For example with the IMEI Number. How i can configure this and where ?
    3. All our Mobile Devices (IOS,Adroid) are registered in SAP Afaria.
    Thx
    Salvatore
  • 2.  RE: Clearpass 6.5.x SAP Afaria installation with IMEI with query
    Posted Mar 04, 2016 10:23 AM
    You can run a manual poll by clicking the Trigger Poll button after selecting the checkbox next to the endpoint context server. You can then go to Audit Viewer and you should see endpoint updates.
    What are you trying to compare the IMEI number to?
    Sent from Nine
  • 3.  RE: Clearpass 6.5.x SAP Afaria installation with IMEI with query
    Posted Jun 07, 2016 06:00 AM
    yes we want to compare the imei number. Is this the best solution to compare ?
    Thx
    Salvatore
  • 4.  RE: Clearpass 6.5.x SAP Afaria installation with IMEI with query
    Posted Mar 04, 2016 11:47 AM
    I have documented numerous authZ solutions in my MDM TechNote. I havn't built one around IMEI but look at the guide and you'll quickly see how you can adapt one of the built ones to check the IMEI and do what ever you need to do.
    FInd it here Tech Note: ClearPass Enterprise Mobility Management Integration V5
  • 5.  RE: Clearpass 6.5.x SAP Afaria installation with IMEI with query
    Posted Mar 08, 2016 02:44 AM
    sorry for the late answer. Now i have asked my MDM sales partner.
    I had asked him to give me Server Base address as Login and Password.
    Now i receive the answer: This is not possible, because this is an MDM Cloud System.
    This is a shared system where other costumer are attached too. Now i`m confused.
    Need now another solution for my mobile devices.
    Is it possible to add all mobile devices manually ??
    We have clearpass and Airwave in use.
    thx
    Salvatore
  • 6.  RE: Clearpass 6.5.x SAP Afaria installation with IMEI with query
    Posted Mar 08, 2016 12:02 PM
    I'm not quite following, but ClearPass can connect to SAP Afaria cloud or on-prem. It sounds like their is confusion on your end. Typically for Afaria you have individual tenant credentials unique to you that provides access to only your registered devices.
