Clearpass 6.6 upgrade woes
  • 1.  Clearpass 6.6 upgrade woes
    Posted Jun 22, 2016 08:34 AM
    Well this is fun. Looking for advice ... see end
    Upgrading from CPPM 6.5.6 to 6.6 - plan is to migrate 1 CPPM appliance at a time from a 6.5.6 cluster to a 6.6 cluster So ....
    build 6.5.6 master publisher vm and restore a backup of our real master publisher into it
    upgrade to 6.6. and check everything works
    leave for week with some auths going through it
    suddenly at 14:22 last thursday event log shows CPU IOWait errors
    Reboot server
    happens again
    mention it to systems - and the clearpass vm is flatlining  the CPU on our netapps
    shutdown clearpass, netapp back to normal, restart VM netapp squeaks
    backup 6.6. config  and destroy VM
    build new VM (clearpassm0)  using the 6.6 OVA
    import config
    System working
    test for normal operation and pass users to it, everything works.
    install (new) hardware appliance running 6.6, make subscriber to above system (clearpass5)
    everything works - now got cluster of 2 machines running 6.6
    # Now for the bad bit
    remove 6.5.6 subscriber from other cluster. (clearpass4)
    Download 6.6 update
    At home - 4:15 this morning click install on update, told it to keep its database configs. BTW backup file ~8Gbytes
    6:30 - hasn't finished yet
    At work 9:15  - ready for reboot - reboot VM
    11:15 - comes back from reboot
    Device working standalone just fine
    Tell it to become subscriber to  clearpassm0
    # This go apes**t!
    master publisher stops authenticating and clearpass5 says cleapassm0 is down
    clearpass4 says its synching
    clearpass5 says its now out of sync.
    ssh into clearpassm0
    type "cluster list"
    console hangs
    ctl-C out of it
    type another command  - that hangs
    reboot clearpassm0
    VMWare says lots of CPU activity
    can SSh into it and commands respond
    no web interface on clearpassm0 after hours
    web interface on clearpass4 tries to do something ( at welcome action page) but nothing appears
    can ssh into clearpass4
    What do I do now? Just leave it for another few hours?
    Feeling is to start again and rebuild all the VMS and ditch the sesion data and insight stuff ..... which is what we actually want to keep!
  • 2.  RE: Clearpass 6.6 upgrade woes
    Posted Jun 22, 2016 11:53 AM
    o.k. got things working, thank god for a command line. However have lost all insight data and what was my new master publisher was totally trashed, none of the cluster ... commands would work including the reset database one. Ended up rebuilding that VM.
    oh well, started the day with a 2 dev cluster and a standalone device and ended day with 2 dev cluster and  a standalone device  .... without any insight or historic data ...
    A
