hello gurus,
i am trying to locate the clearpass preparation patch to upgrade from 6.5.0 to 6.6.0
cant seem to locate on the aruba software support site.
any ideas
Below links provide upgrade guide and upgrade/patches to download
https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Default.aspx?EntryId=21179
https://support.arubanetworks.com/DownloadSoftware/tabid/75/DMXModule/510/Default.aspx?EntryId=8157
Pavan
thanks for your reply Pavan.
the only problem is neither of those links take me to the software patch i am after.
any ideas what i am doing wrong?
pete
Do you have access to Aruba support site? Click on links first will take you to page where you could download guide which proivde steps to upgrade and second to donwload patches/upgrade image.
Which screen page does it taking you when you click on below links?
the screen takes me to the documentation that's fine.
and i can see other software versions but not the patch.
When you click on second link and login, We have patches and upgrade folder where we could get minor patches and upgrade image.
hi Pavan,
found it under 6.5.
thanks for your help.
cheers
first hello to every one.
if i set the threshold 50 and interval 5 minute.....what will happed if fail authentication exceed the 50 threshold to 60 then will it send an email or it must be btween 1-50 threshold.
thanks for your repond.
