Clearpass 6.7 Certificate renewal
This thread has been viewed 24 times
  • 1.  Clearpass 6.7 Certificate renewal
    Posted Aug 22, 2019 04:36 AM
    hello Airheads,
    we have a publicly registered certiifcate on our 6.7 Clearpass.
    It's registered with GODADDY and it's just about to expire.
    There is an option to renews on the GODADDY website.
    However can i do this and simply import to Clearpass.
    OR do i have to submit another CSR?
    CHEERS
    PETE
  • 2.  RE: Clearpass 6.7 Certificate renewal
    Posted Aug 22, 2019 09:02 AM
    Just need to submit a new CSR with the same common name you are using now
    Is this for RADIUS authentication ?
    Thank you
    Victor Fabian
    Pardon typos sent from Mobile
  • 3.  RE: Clearpass 6.7 Certificate renewal
    Posted Aug 22, 2019 09:07 AM
    thanks Victor,
    i thought you did, just wasn't sure.
    Now i've heard it from the the main man i'm good to go.
    cheers
    pete
  • 4.  RE: Clearpass 6.7 Certificate renewal
    Posted Aug 22, 2019 11:43 AM
    If you are replacing the RADIUS certificate and the chain changed , users will need to accept a new certificate
    So to replacing the certificate you should plan in the event the cert chain changed
    Thank you
    Victor Fabian
  • 5.  RE: Clearpass 6.7 Certificate renewal
    Posted Aug 22, 2019 11:48 AM
    thanks again for info Victor
  • 6.  RE: Clearpass 6.7 Certificate renewal
    Posted Oct 03, 2019 11:23 AM
    You will have to create a new CSR, then in GoDaddy locate your certificate and use the "rekey" option, paste the CSR there and once is approved download your new .cer that you can update in your clearpass.
