Clearpass 6.7 CoA / RADSESC AOS8.4
  • 1.  Clearpass 6.7 CoA / RADSESC AOS8.4
    Posted Jun 13, 2019 07:44 PM
    When I configure RADSEC on my AAA server in AOS, CoA stops functioning. I receive the error: "Network Device did not respond." When I disable RADSEC everything works as intended.
    I currently have the NAS-IP set at the MD level.
    I also enabled RADSEC at the rfc-3576 server level via CLI with the same results.
    Is this a known issue, or am I missing a step in the configuration?
  • 2.  RE: Clearpass 6.7 CoA / RADSESC AOS8.4
    Posted Jun 14, 2019 05:43 AM
    If this is a cluster, RadSec is not supported in a cluster today.
  • 3.  RE: Clearpass 6.7 CoA / RADSESC AOS8.4
    Posted Jun 14, 2019 09:22 AM
    On which side ? I'm assuming you mean the controllers?
  • 4.  RE: Clearpass 6.7 CoA / RADSESC AOS8.4
    Posted Jun 14, 2019 09:40 AM
    Correct.
  • 5.  RE: Clearpass 6.7 CoA / RADSESC AOS8.4
    Posted Jun 14, 2019 09:43 AM
    Thanks, Tim.
    I did want to mention that Radsec seems to work fine on its own. It's just that CoA stops functioning if you enable it. I guess that's the 'not supported' part.
  • 6.  RE: Clearpass 6.7 CoA / RADSESC AOS8.4
    Posted Jun 14, 2019 11:39 AM
    Correct. Dynamic Authorization is part of RadSec.
