ClearPass 6.7 licenses for an HA cluster
  • 1.  ClearPass 6.7 licenses for an HA cluster
    Posted Dec 31, 2018 12:34 PM
    Hi
    I have a question, if I have 2 "Aruba ClearPass C2000" with 1 "Aruba ClearPass NL AC 2500 CE E-LTU", 1 "Aruba ClearPass NL OB 100 USR E-LTU", and 1 "Aruba ClearPass NL OG 100 EP E-LTU installed" on the CLUSTER, which are currently in 1 + 1 mode. Will the OnBoard and OnGuard licenses be lost if any of the 2 appliances goes down?
    Regard,
    Carlos Villanueva
  • 2.  RE: ClearPass 6.7 licenses for an HA cluster
    Posted Dec 31, 2018 02:03 PM
    Licenses are "pooled" for the entire cluster to use. As long as your cluster and failover is configured correctly there will not be any problems.
  • 3.  RE: ClearPass 6.7 licenses for an HA cluster
    Posted Dec 31, 2018 02:52 PM
    So, do I not need to buy more OnBoard and OnGuard licenses to have high availability?
  • 4.  RE: ClearPass 6.7 licenses for an HA cluster
    Posted Dec 31, 2018 04:03 PM
    As long as everything is configured correctly and both your Clearpass servers are in the same cluster then you need as many Onboard and Onguard licenses as you will consume. You do not need to buy additional for HA. Again as long as everything is configured correctly.
  • 5.  RE: ClearPass 6.7 licenses for an HA cluster
    Posted Jan 02, 2019 10:27 AM
    Thank you very much, for versions before 6.7, is it the same?.
