Hi Rob
If you can contact Aruba TAC or should contact your IT partner depends on what type of support agreement you have. If you have the standard support you may contact Aruba directly, but if you have partner branded support you should contact your IT partner.
Maybe you need to ask your partner about the type of support if you don't have the information at hand.
Best Regards
Jonas Hammarbäck
MVP 2023, ACCX #1335, ACMP, ACDP, ACP-Network Security, ACEP, ACSA
Aranya AB
Original Message:
Sent: Mar 10, 2023 01:59 AM
Subject: Clearpass 6.9.13 HF1 -> Profiler unstable
A reboot sadly doesn't fix the problem.
Is it possible for me to contact TAC directly? Without our IT-partner or do I need them for the call?
Original Message:
Sent: Mar 09, 2023 10:40 AM
I have not. Does a reboot fix this? This may be a TAC call....
Dustin Burns
ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2022-2023
Original Message:
Sent: Mar 09, 2023 03:58 AM
Hi there!
I've updated our Clearpass servers to 6.9.13 Hotfix 1 and now every hour there's an error message for the profiler.
The message says that both of our profilers are unstable and clients aren't profiled anymore. See screenshots below:
Anyone else had this problem or knows an solution?
Thank you for you're reply!
Best regards, Rob
