Clearpass 802.1x EAP PEAP FAILOVER
  • 1.  Clearpass 802.1x EAP PEAP FAILOVER
    Posted Apr 01, 2019 11:28 AM
    Hi
    we have a clearpass server per location. and for the failure we take the provisioning cluster.
    so the config on the switch is:
    (1.1.1.1 for clearpass in site and 2.2.2.2 for clearpass cluster)
    radius-server host 1.1.1.1 key "here-is-my-key"
    radius-server host 1.1.1.1 dyn-authorization
    radius-server host 1.1.1.1 time-window 0
    radius-server host 2.2.2.2 key "here-is-my-key"
    radius-server host 2.2.2.2 dyn-authorization
    radius-server host 2.2.2.2 time-window 0
    aaa accounting update periodic 3
    aaa accounting network start-stop radius
    aaa authentication port-access eap-radius
    aaa port-access authenticator
    aaa port-access mac-based a1 addr-limit 2
    aaa port-access authenticator a1 client-limit 2
    so i have a pc on a1 and it works with clearpass perfect
    but if I simulate a failover of 1.1.1.1 only mac-authentication works
    for 802.1x the error message comes: did not complete eap transaction
    I have tested a lot and found the following out:
    if I delete 1.1.1.1 and only 2.2.2.2 is in the list also works clearpass (so it is not the access to 2.2.2.2)
    if I then re-enter the 1.1.1.1 as the first radius server and make a failover it works too!
    So I summarize: if i simulate a failover for 1.1.1.1 server and before never made a connection to 2.2.2.2, it does not work!
    have now after the weekend again a failover tested on the same switch and the error was there again. what the switch notices seem to be lost after a time .. radius certificate?
    what goes wrong when switching the server on the switch?
    someone had the mistake?
  • 2.  RE: Clearpass 802.1x EAP PEAP FAILOVER
    Posted Apr 05, 2019 06:30 AM
    I found the mistake. The case can be closed.
    The solution was: radius-server retransmit 1
  • 3.  RE: Clearpass 802.1x EAP PEAP FAILOVER
    Posted Aug 02, 2019 09:51 AM
    You need the radius-server timeout command
    Sent from Mail for Windows 10
