ClearPass - 802.1x In front of G-Suite with Ldap connector - is it possiabble? (using only user and password?)
This thread has been viewed 41 times
  • 1.  ClearPass - 802.1x In front of G-Suite with Ldap connector - is it possiabble? (using only user and password?)
    Posted Jul 06, 2021 10:11 AM
    Hi AirHeads,
    I just started a small PoC with ClearPass at one of my clients, He would like to create 802.1x in front of his employees DB located behind G-Suite (Google Services)
    I follow the guides in order to create the G-Suite as a auth source,And i even can scan the group/user/tree from the CPPM
    Screenshot:
    , But when i was trying to create 802.1x (U/P) networks based on that auth sources..user auth keeps failed. (Even due user is not failing in front of the G-Suite auth)
    A. Should it work? (And if Yes,Is there any doc about it ?
    B. Is on SAML/OAUTH2 with CP ONBOARD is possible?
    C. any tip regarding this manner of connecting G-Suite to CPPM in order to auth 802.1x in front of it will be lovely ..Agian ...If its possible at all.
    Thanks.
    Me
    (*) If i helped you , Please do kudos me as a thank you (*)
    Aruba AirHeads - Because mobility matters.
  • 2.  RE: ClearPass - 802.1x In front of G-Suite with Ldap connector - is it possiabble? (using only user and password?)
    Posted Jul 06, 2021 10:27 AM
    EAP-TLS is required for cloud identity providers. The Google Secure LDAP extension is supported for authorization only.
    Tim C
  • 3.  RE: ClearPass - 802.1x In front of G-Suite with Ldap connector - is it possiabble? (using only user and password?)
    Posted Jul 06, 2021 11:06 AM
    Thanks for the fast response,
    So the cert should arrived from Google or the CPPM itself?
  • 4.  RE: ClearPass - 802.1x In front of G-Suite with Ldap connector - is it possiabble? (using only user and password?)
    Posted Jul 06, 2021 11:11 AM
    For managed devices, it should come via the EMM. For unmanaged devices, users can enroll using CPPM Onboard or another solution.
    Tim C
  • 5.  RE: ClearPass - 802.1x In front of G-Suite with Ldap connector - is it possiabble? (using only user and password?)
    Posted Jul 07, 2021 07:34 PM
    It is possible with onboarding.   You can't use Google Secure LDAP for direct 802.1x.  But can use it as authentication source for onboarding process and then use EAP-TLS  (Clearpass as CA) and  G. SLDAP for authorisation.
    Asela Abhayapala
  • 6.  RE: ClearPass - 802.1x In front of G-Suite with Ldap connector - is it possiabble? (using only user and password?)
    Posted Jul 13, 2021 04:48 AM
    Short update regarding the PoC im demonstrating, Based on the info @Asela and @timms sent my in the previous threads , I was able to Connect  users and verify and auth their account on google via cppm onboard  (Than they got CERT + Profile) , And created the OnBoard process on iOS and PC , But when the profile is being tried to being pushed the the client device (MAC to WINDOWS) im getting strange errors:
    Anyone can please advise , what might be the cause of such an errors , and how to overcome them - it's the last stage before i will finish the PoC and the client will be the CPPM as an added value for his current Aruba deployment.
    Thanks in advance to who that might assist me with some tips  / guide, walktrough to solve these errors.
    BTW: Attached error log of Windows (PC) User:
    Client Log
    2021-07-08 14:15:16,508 [main] DEBUG Quick1X.QuickConnectDlg - Starting configuration.
    2021-07-08 14:15:16,508 [main] DEBUG changelog - Starting configuration for secure network connections.
    2021-07-08 14:15:16,508 [main] DEBUG Quick1X.Util - Attempting operating system detection.
    2021-07-08 14:15:16,508 [main] DEBUG Quick1X.Util - running Windows Enterprise Version
    2021-07-08 14:15:16,509 [main] DEBUG Quick1X.Util - Detected operating system higher than Windows XP
    2021-07-08 14:15:16,509 [main] DEBUG Quick1X.WlanApi - Initializing wlan api.
    2021-07-08 14:15:16,509 [main] DEBUG Quick1X.Config - Initing configuration.
    2021-07-08 14:15:16,509 [main] DEBUG Quick1X.Config - QuickConnect Mode isonboard
    2021-07-08 14:15:17,229 [main] DEBUG Quick1X.QuickConnectDlg - Calling javascript method : updateWorkingDirectory
    2021-07-08 14:15:19,730 [main] DEBUG Quick1X.QuickConnectDlg - Calling javascript method : updateQcMode
    2021-07-08 14:15:19,756 [main] DEBUG Quick1X.QuickConnectDlg - Processing configure
    2021-07-08 14:15:19,757 [null] DEBUG Quick1X.QuickConnectDlg - Processsing configure task
    2021-07-08 14:15:19,757 [null] DEBUG Quick1X.QuickConnectDlg - Fetching the configuration and certificate from the Onboard Server
    2021-07-08 14:15:19,757 [null] DEBUG Quick1X.QuickConnectDlg - Initing device info
    2021-07-08 14:15:19,757 [null] DEBUG Quick1X.DeviceInfo - Starting interface detection
    2021-07-08 14:15:19,757 [null] DEBUG Quick1X.Util - Running config task as logged in user
    2021-07-08 14:15:19,911 [null] DEBUG Quick1X.Util - Exit code from execed process 0
    2021-07-08 14:15:19,924 [null] DEBUG Quick1X.DeviceInfo - Checking interface :Intel(R) Ethernet Connection (4) I219-LM
    2021-07-08 14:15:19,924 [null] DEBUG Quick1X.DeviceInfo - Interface Type     :6
    2021-07-08 14:15:19,924 [null] DEBUG Quick1X.DeviceInfo - Interface state    :2
    2021-07-08 14:15:19,924 [null] DEBUG Quick1X.DeviceInfo - Trying to filter :Intel(R) Ethernet Connection (4) I219-LM
    2021-07-08 14:15:19,924 [null] DEBUG Quick1X.DeviceInfo - Trying to filter (Unicode) :Intel(R) Ethernet Connection (4) I219-LM
    2021-07-08 14:15:19,924 [null] DEBUG Quick1X.DeviceInfo - Adapter GUID:75989E59-A656-40D4-A04C-4C226B8137C8
    2021-07-08 14:15:19,924 [null] DEBUG Quick1X.DeviceInfo - Description: Intel(R) Ethernet Connection (4) I219-LM
    2021-07-08 14:15:19,924 [null] DEBUG Quick1X.DeviceInfo - Name: Ethernet
    2021-07-08 14:15:19,924 [null] DEBUG Quick1X.DeviceInfo - State: DISCONNECTED
    2021-07-08 14:15:19,924 [null] DEBUG Quick1X.DeviceInfo - DHCP : Enabled
    2021-07-08 14:15:19,924 [null] DEBUG Quick1X.DeviceInfo - DNS Registration: Enabled
    2021-07-08 14:15:19,924 [null] DEBUG Quick1X.DeviceInfo - DNS by DHCP: Enabled
    2021-07-08 14:15:19,924 [null] DEBUG Quick1X.DeviceInfo - MAC Address: C8:F7:50:10:8D:97
    2021-07-08 14:15:19,925 [null] DEBUG Quick1X.DeviceInfo - Interface type : Wired
    2021-07-08 14:15:19,925 [null] DEBUG Quick1X.DeviceInfo - Checking interface :Microsoft Wi-Fi Direct Virtual Adapter
    2021-07-08 14:15:19,925 [null] DEBUG Quick1X.DeviceInfo - Interface Type     :71
    2021-07-08 14:15:19,925 [null] DEBUG Quick1X.DeviceInfo - Interface state    :2
    2021-07-08 14:15:19,925 [null] DEBUG Quick1X.DeviceInfo - Trying to filter :Microsoft Wi-Fi Direct Virtual Adapter
    2021-07-08 14:15:19,925 [null] DEBUG Quick1X.DeviceInfo - Discarding interface : Microsoft Wi-Fi Direct Virtual Adapter
    2021-07-08 14:15:19,925 [null] DEBUG Quick1X.DeviceInfo - Checking interface :Microsoft Wi-Fi Direct Virtual Adapter #2
    2021-07-08 14:15:19,925 [null] DEBUG Quick1X.DeviceInfo - Trying to filter :Microsoft Wi-Fi Direct Virtual Adapter #2
    2021-07-08 14:15:19,925 [null] DEBUG Quick1X.DeviceInfo - Discarding interface : Microsoft Wi-Fi Direct Virtual Adapter #2
    2021-07-08 14:15:19,925 [null] DEBUG Quick1X.DeviceInfo - Checking interface :Intel(R) Dual Band Wireless-AC 8265
    2021-07-08 14:15:19,925 [null] DEBUG Quick1X.DeviceInfo - Interface state    :1
    2021-07-08 14:15:19,925 [null] DEBUG Quick1X.DeviceInfo - Trying to filter :Intel(R) Dual Band Wireless-AC 8265
    2021-07-08 14:15:19,925 [null] DEBUG Quick1X.DeviceInfo - Trying to filter (Unicode) :Intel(R) Dual Band Wireless-AC 8265
    2021-07-08 14:15:19,925 [null] DEBUG Quick1X.DeviceInfo - Adapter GUID:8AEA6876-6590-4FA7-A239-572C324BD1B4
    2021-07-08 14:15:19,925 [null] DEBUG Quick1X.DeviceInfo - Description: Intel(R) Dual Band Wireless-AC 8265
    2021-07-08 14:15:19,925 [null] DEBUG Quick1X.DeviceInfo - Name: Wi-Fi
    2021-07-08 14:15:19,925 [null] DEBUG Quick1X.DeviceInfo - State: CONNECTED
    2021-07-08 14:15:19,925 [null] DEBUG Quick1X.DeviceInfo - DHCP : Enabled
    2021-07-08 14:15:19,925 [null] DEBUG Quick1X.DeviceInfo - DNS Registration: Enabled
    2021-07-08 14:15:19,925 [null] DEBUG Quick1X.DeviceInfo - DNS by DHCP: Enabled
    2021-07-08 14:15:19,925 [null] DEBUG Quick1X.DeviceInfo - MAC Address: 50:76:AF:19:8C:50
    2021-07-08 14:15:19,925 [null] DEBUG Quick1X.DeviceInfo - Interface type : Wireless
    2021-07-08 14:15:19,925 [null] DEBUG Quick1X.DeviceInfo - Checking interface :Bluetooth Device (Personal Area Network)
    2021-07-08 14:15:19,925 [null] DEBUG Quick1X.DeviceInfo - Interface Type     :6
    2021-07-08 14:15:19,925 [null] DEBUG Quick1X.DeviceInfo - Trying to filter :Bluetooth Device (Personal Area Network)
    2021-07-08 14:15:19,925 [null] DEBUG Quick1X.DeviceInfo - Discarding interface : Bluetooth Device (Personal Area Network)
    2021-07-08 14:15:19,925 [null] DEBUG Quick1X.DeviceInfo - Checking interface :Software Loopback Interface 1
    2021-07-08 14:15:19,925 [null] DEBUG Quick1X.DeviceInfo - Interface Type     :24
    2021-07-08 14:15:19,926 [null] DEBUG Quick1X.QuickConnectDlg - Downloading device credentials from the Onboard server - https://cppmdemo.2plus.co.il/onboard/mdps_qc_enroll.php
    2021-07-08 14:15:19,926 [null] DEBUG Quick1X.QuickConnectDlg - Checking whether bypass proxy is false or true
    2021-07-08 14:15:19,926 [null] DEBUG Quick1X.QuickConnectDlg - Bypass proxy is false
    2021-07-08 14:15:19,926 [null] DEBUG Quick1X.QuickConnectDlg - Onboard server Host Name cppmdemo.2plus.co.il
    2021-07-08 14:15:19,926 [null] DEBUG Quick1X.QuickConnectDlg - Onboard server URL Path /onboard/mdps_qc_enroll.php
    2021-07-08 14:15:19,926 [null] DEBUG Quick1X.QuickConnectDlg - Retrieving value of Validate-Server-Certificate option
    2021-07-08 14:15:19,926 [null] INFO  Quick1X.QuickConnectDlg - Disabling Onboard server certificate validation
    2021-07-08 14:15:19,926 [null] DEBUG Quick1X.QuickConnectDlg - Detected Windows version - Windows 10
    2021-07-08 14:15:20,178 [null] ERROR Quick1X.QuickConnectDlg - Received error HTTP Status code - 403
    2021-07-08 14:15:20,178 [null] DEBUG Quick1X.Util - Running config task as logged in user
    Script Log
    08/07/2021 13:23:17   Adapter type detect starting
    08/07/2021 13:23:17   Intel(R) Ethernet Connection (4) I219-LM  Type: 0
    08/07/2021 13:23:17   Intel(R) Dual Band Wireless-AC 8265  Type: 9
    08/07/2021 13:23:17   Bluetooth Device (Personal Area Network)  Type: 10
    08/07/2021 13:23:17   Microsoft Wi-Fi Direct Virtual Adapter  Type: 9
    08/07/2021 13:23:17   Microsoft Wi-Fi Direct Virtual Adapter #2  Type: 9
    08/07/2021 14:15:19   Adapter type detect starting
    08/07/2021 14:15:19   Intel(R) Ethernet Connection (4) I219-LM  Type: 0
    08/07/2021 14:15:19   Intel(R) Dual Band Wireless-AC 8265  Type: 9
    08/07/2021 14:15:19   Bluetooth Device (Personal Area Network)  Type: 10
    08/07/2021 14:15:19   Microsoft Wi-Fi Direct Virtual Adapter  Type: 9
    08/07/2021 14:15:19   Microsoft Wi-Fi Direct Virtual Adapter #2  Type: 9
    Helper Log
  • 7.  RE: ClearPass - 802.1x In front of G-Suite with Ldap connector - is it possiabble? (using only user and password?)
    Posted Jul 13, 2021 10:32 AM
    What does the CPG application log show?
    Tim C
  • 8.  RE: ClearPass - 802.1x In front of G-Suite with Ldap connector - is it possiabble? (using only user and password?)
    Posted Jul 13, 2021 02:28 PM
    Hi
    You mean this log?!:
    Or which CPG log? Please advise - i need info , Tomorrow im on-site.
  • 9.  RE: ClearPass - 802.1x In front of G-Suite with Ldap connector - is it possiabble? (using only user and password?)
    Posted Jul 16, 2021 09:50 AM
    Do you have a trusted public certificate on your ClearPass server(s)? If not, get one and test again. In my experience, IOS will reject profiles unless sent over a trusted HTTPS connection.
    It really is not worth the effort to try to get things to work without a trusted public certificate.
    Also, first try Onboarding with a local account, for which you know it works. If it works there, switch to SAML/OAuth2 SSO.
  • 10.  RE: ClearPass - 802.1x In front of G-Suite with Ldap connector - is it possiabble? (using only user and password?)
    Posted Jul 16, 2021 12:06 PM
    Hi
    Thanks for the tip,BUT,
    The onboard process done with public signed cert that were deployed on the cppm and used during the onboarding process.
    on IOS it's marked as verified and also the onboard profile marked with green verified.
    But i guess it's something i missed or something  in the service i built based on the SAML/OAUTH2 Guide, (Attached to this post as a PDF)
    Because when i create ONBOARD service from the wizard it's seems to be working :) But yet i dunno , why...it's got back user without any fitted service before i created one with the wizard...
    I still hope , Some Airheads & CPPM guru will be able to assist me to figure , What did i missed.
  • 11.  RE: ClearPass - 802.1x In front of G-Suite with Ldap connector - is it possiabble? (using only user and password?)
    Posted Jul 16, 2021 01:01 PM
    The Onboard Authorization service is missing. Create it manually or use the wizard / service template.
    Tim C
