Clearpass 802.1X MFA
  • 1.  Clearpass 802.1X MFA
    Posted Oct 30, 2017 06:43 AM
    Hi All
    Can anyone point me at some documentation on how to intergrate an MFA provider (Duo) with Clearpass when doing 802.1X.
    Dave
  • 2.  RE: Clearpass 802.1X MFA
    Posted Oct 30, 2017 08:03 AM
    We don't have it documented (it's on the list). What specifically so you need help with?
  • 3.  RE: Clearpass 802.1X MFA
    Posted Oct 30, 2017 12:48 PM
    Hi Tim
    Just interested to know what the work flow is to get me started. Is it best to do a dot1X authentication and pass back a captive portal role, then do a web auth via Guest for the second factor (or is there a cleaver way to do this with a web form that auto submits to get the push notification). Or do you need to use the Duo RADIUS proxy and set Clearpass as the primary authentication source ?
    Dave
  • 4.  RE: Clearpass 802.1X MFA
    Posted Oct 30, 2017 12:55 PM
    Traditional RADIUS-based MFA is not recommended with 802.1X. We recommend the "sandwich" flow which will occasionally redirect the user to an informational captive portal which will trigger the push notification. It is not recommended to challenge an MFA for every single authentication.
