ClearPass 802.1x service for Aruba Cluster
  • 1.  ClearPass 802.1x service for Aruba Cluster
    Posted Nov 29, 2018 07:08 AM
    I have four Aruba 7220 controllers in cluster with VRRP on each controller plus VRRP IP for "aruba-master" for new APs. Everything managed from Mobility Master.
    Client AD authentication - Do I need to setup four 802.1x Services on ClearPass server to get 802.1x work or can I use only one service there I have all four controllers together, in same service?
    What is a best-practice?
  • 2.  RE: ClearPass 802.1x service for Aruba Cluster
    Posted Nov 29, 2018 07:22 AM
    In most cases one service for wireless 802.1X should be fine
    Thank you
    Victor Fabian
    Pardon typos sent from Mobile
  • 3.  RE: ClearPass 802.1x service for Aruba Cluster
    Posted Nov 29, 2018 07:47 AM
    Thanks for your fast reply!
    Well, that's what I tried to do but...
    I have APs and clients on all four Aruba controllers which means that authentications request coming from all four controllers. And as 802.1x service is build I can't have a NAD-gruop only one MD per service, or?
    See attached file.
    How you guys do with authentications coming from Aruba Cluster and from different controllers?
  • 4.  RE: ClearPass 802.1x service for Aruba Cluster
    Posted Nov 29, 2018 09:38 AM
    You can create a device attribute under configuration > network devices > attribute tab > device (device type or device id) and then you can include that in the service
    Sent from Mail for Windows 10
  • 5.  RE: ClearPass 802.1x service for Aruba Cluster
    Posted Dec 04, 2018 07:19 AM
    I would choose one of the following options:
    1. Configure a device group under Configuration >> Network >> Device Group and match the device group in the service
    2. Use a regular expression in the service
    Check the screenshot for an example
  • 6.  RE: ClearPass 802.1x service for Aruba Cluster
    Posted Nov 29, 2018 09:25 AM
    Just put all the controller IPs in one NAD group. Also keep in mind that using NAS groups is optional.
