Clearpass 802.1x with active directory
  • 1.  Clearpass 802.1x with active directory
    Posted Apr 26, 2017 03:37 PM
    Hello everyone:
    I've installed the Clearpass (6.6.0.81015) and now I trying to configure
    Aruba 802.1X Wireless, however the user can't connect to the network.
    I configured the Clearpss with Instant.
    This is my procedure.
    Instant:
    My Guest network is working fine.
    ClearPass
    Network
    -Device
    802.1x wireless:
    services
    Authentication
    Authorization
    Clearpass was joined to Domain Controller.
    When the user tries to connect to the SSID, the connection faild. I was monitoring the access tracker and I found this error.
    I don't know how to resolve this issue.
    Anyone can help?
    Thanks in advance
    Regards
  • 2.  RE: Clearpass 802.1x with active directory
    Posted Apr 26, 2017 03:44 PM
    Are you trying to use username/password or certificates?
    Is the client supplicant configured?
    What type of client?
  • 3.  RE: Clearpass 802.1x with active directory
    Posted Apr 26, 2017 03:52 PM
    Hi.
    I'm trying to use username/password.
    When exactly I configure the client supplicant?
  • 4.  RE: Clearpass 802.1x with active directory
    Posted Apr 26, 2017 03:55 PM
    Do you have a public CA-signed RADIUS server certificate or internal/private?
  • 5.  RE: Clearpass 802.1x with active directory
    Posted Apr 26, 2017 04:52 PM
    I don't have RADIUS server certificate configured. this server should be configure on windows server
  • 6.  RE: Clearpass 802.1x with active directory
    Posted Apr 26, 2017 04:55 PM
    You will need to configure a RADIUS/EAP server certificate in ClearPass.
  • 7.  RE: Clearpass 802.1x with active directory
    Posted Apr 26, 2017 08:15 PM
    Hi again..
    thanks for your reply.
    I was trying to configure RADIUS/EAP server certificate, but I couldn't complete all steps, so I think that I'm making a mistake.
    Do you know..or do you have any link that can you share about this configuration...?
    thanks a lot
  • 8.  RE: Clearpass 802.1x with active directory
  • 9.  RE: Clearpass 802.1x with active directory
    Posted May 04, 2017 03:36 PM
    Hi.
    Thanks for your reply. I've configured Clearpass with that procedure.
    Thank you so much.
