ClearPass Access License
  • 1.  ClearPass Access License
    Posted Jan 22, 2019 05:51 PM
    Hi experts
    If I have a laptop with the OnGuard client connected to a WiFi network, and after 2 hours I connect the network cable. How many Acces licenses do you consume? I understand that you only use 1 OnGuard license, but it is not clear to me in Access what you mean when you say "Endpoint" "Access licenses are consumed based upon concurrent authenticated / authorized endpoints."
    Regards
  • 2.  RE: ClearPass Access License
    Posted Jan 22, 2019 06:08 PM
    1 access license per network session per MAC address.
  • 3.  RE: ClearPass Access License
    Posted Jan 22, 2019 06:15 PM
    Hi Tim, thanks for your reply
    So, in this case, in which I connect to the network through WiFi and Cable at the same time, would I consume 2 access licenses and 1 OnGuard?
    Regards
  • 4.  RE: ClearPass Access License
    Posted Jan 22, 2019 06:26 PM
    Yes. Why would you be connected to both at the same time?
  • 5.  RE: ClearPass Access License
    Posted Jan 22, 2019 06:35 PM
    Hi Tim
    What happens is that there are many workers who move constantly inside the company with their laptop, for this they use the WiFi network, but when they return to their place of work, they use their network cable. And when you connect your network cable, the WiFi network is still active, so I asked the question.
    Regards
  • 6.  RE: ClearPass Access License
    Posted Jan 22, 2019 06:57 PM
    I would highly recommend that behavior be disabled in the BIOS (assuming Windows). Devices should never sit on two networks.
  • 7.  RE: ClearPass Access License
    Posted Jan 22, 2019 07:03 PM
    I will contact the IT manager to indicate the recommendation, thank you very much, Tim.
    Regards
