ClearPass access tracker
  • 1.  ClearPass access tracker
    Posted Aug 16, 2016 03:17 AM
    I am not able to see access tracker logs in Publisher from the other cluster nodes.
    I received an message: 'Waiting to complete current operation...'  and
    after a while an error message: 'Database connection failure: Host may be disconnected; please retry.'  when I am trying to check it.
    Of course the servers are running and I can check access tracker logs locally on every server.
    Does anyone have the same issue? I am running ClearPass Policy Manager 6.6.0.81015
  • 2.  RE: ClearPass access tracker
    Posted Aug 16, 2016 05:17 AM
    Do you have a firewall in between your publisher and subscriber nodes?
    Specific ports are required to open the logs on the other nodes in the cluster.
  • 3.  RE: ClearPass access tracker
    Posted Aug 16, 2016 08:33 AM
    It looks like there is. I have to confirm it with network team.
    Could you tell me if I should open firewall for mgmt or data interface?
  • 4.  RE: ClearPass access tracker
    Posted Aug 16, 2016 08:38 AM
    I would imagine it would be the mgmt interface but you can check by connecting to the CLI of the ClearPass appliance and running "network ip list".
  • 5.  RE: ClearPass access tracker
    Posted Sep 28, 2016 10:42 AM
    We have the same issue with the error "Database connection failure: Host may be disconnected; please retry" this connection does go through the firewall.  It has happened once we upgraded tothe 6.6.2 patch.
  • 6.  RE: ClearPass access tracker
    Posted Sep 28, 2016 10:50 AM
    Have you opened a TAC ticket so that they can take a closer look?
