ClearPass and Active Directory
  • 1.  ClearPass and Active Directory
    Posted Jul 06, 2018 12:01 PM
    Hi guys,
    In ClearPass we can add AD as Authentication Source (Configuration > Authentication > Sources) and joining the AD domain (Administration > Server Manager > Server Configuration > Join AD Domain).
    What is the difference between both? Can we join the AD domain without adding the AD as Authentication Source? What is the use of each part?
    Julián
  • 2.  RE: ClearPass and Active Directory
    Posted Jul 06, 2018 12:08 PM
    Domain join is required for legacy EAP methods like PEAP to validate the password. The auth source is used to derive the SID, for authorization functions and for non-EAP authentication.
  • 3.  RE: ClearPass and Active Directory
    Posted Jul 06, 2018 12:14 PM
    Yes, for EAP-TLS ClearPass doesn't need to join the AD domain. Then when dealing with PEAP, can we join the AD domain without adding the AD as auth source?
    Julián
  • 4.  RE: ClearPass and Active Directory
    Posted Jul 06, 2018 12:16 PM
    RE: EAP-TLs, correct
    RE: PEAP, you need both
  • 5.  RE: ClearPass and Active Directory
    Posted Jul 06, 2018 12:18 PM
    Ok, many thanks!
    Julián
