ClearPass and Check Point integration - still not working
  • 1.  ClearPass and Check Point integration - still not working
    Posted Jul 13, 2022 01:42 PM
    Hi everyone,
    I'm following the (old) guide about integrating the authentications to ClearPass in order to have logs on my Check Point cluster firewall, but I still cannot see any log in or log off action.
    ClearPass: 6.7.0.101814
    CheckPoint: cluster of 2 R80.40
    I've double checked all the steps and configurations, everything looks right like in the document.
    Users can connect to the wifi SSID but I can't see their login in the CP CLI (pdp command).
    Is this a problem on the firewall or on clearpass?
    Do anyone have a working configuration to post to check if I made a mistake?
    thanks!
  • 2.  RE: ClearPass and Check Point integration - still not working
    Posted Jul 22, 2022 09:52 PM
    clearpass 6.7.x is end of support, so you need to upgrade to at least 6.9.x
    here is the checkpoint integration guide with clearpass 6.9.1
    https://support.hpe.com/hpesc/public/docDisplay?docId=a00101500en_us
