Clearpass and Cisco switch intgration
  • 1.  Clearpass and Cisco switch intgration
    Posted Sep 11, 2016 06:13 AM
    We have done following configuration on cisco switch and dot1x authentications are working fine on clearpass. However we are getting repeated radius requets on clearpass with login status as "accept" due to which users are facing intermittent disconnection issue. Please help.
    ip device tracking
    aaa new-model
    aaa authorization network default local group radius
    radius-server vsa send authentication
    radius-server host <CPPM IP> auth-port 1812 acct-port 1813 key <secret key>
    radius-server host <CPPM IP> key 7 <secret key>
    radius-server retry method reorder
    radius-server retransmit 3
    radius-server timeout 15
    radius-server deadtime 15
    aaa authentication dot1x default group radius local
    aaa authorization auth-proxy default group radius
    aaa accounting dot1x default start-stop group radius
    dot1x system-auth-control
    aaa server radius dynamic-author
    client <CPPM IP> server-key <secret key>
    port 3799
    auth-type all
    ip access-list extended CPG
    deny tcp any host <CPPM IP>
    permit tcp any any
    interface GigabitEthernet1/0/12
    switchport access vlan <VLAN>
    switchport mode access
    authentication order dot1x mab
    authentication priority dot1x mab
    authentication port-control auto
    authentication periodic
    authentication timer reauthenticate server
    mab
    dot1x pae authenticator
    dot1x timeout tx-period 3
    dot1x max-reauth-req 2
    dot1x max-req 2
    dot1x timeout supp-timeout 20
    spanning-tree portfast
