last person joined: 10 hours ago
Clearpass and Elasticsearch, Logstash, and Kibana (ELK)
  • 1.  Clearpass and Elasticsearch, Logstash, and Kibana (ELK)
    Posted Feb 17, 2015 11:51 AM
    Has anyone used Clearpass Syslog Targets with the ELK (Elasticsearch, Logstash, and Kibana)  Stack?
    I'm getting data into ELK by using the SYSLOG Splunk export filters provided in the Splunk Integration Guide and the following Logstash configuration:
    I'm wondering if anyone has created a Kibana dashboard to analyze the results.
    Thanks.
    input {
    tcp {
    port => 5000
    type => syslog
    udp {
    port => 5000
    type => syslog
    filter {
    if [type] == "syslog" and [message] =~ "CPPM" {
    grok {
    match => { "message" => "<%{POSINT:syslog_pri}>%{TIMESTAMP_ISO8601:syslog_timestamp} %{SYSLOGHOST:syslog_hostname} %{DATA&colon;syslog_program} %{POSINT:syslog_pid} 1 0 %{GREEDYDATA&colon;syslog_message}" }
    kv {
    source => "syslog_message"
    field_split => ","
    prefix => "CPPM_"
    add_tag => "CPPM, grokkd"
    else if [type] == "syslog" {
    grok {
    match => { "message" => "<%{POSINT:syslog_pri}>%{SYSLOGTIMESTAMP:syslog_timestamp} %{SYSLOGHOST:syslog_hostname} %{DATA&colon;syslog_program}(?:\[%{POSINT:syslog_pid}\])?: %{GREEDYDATA&colon;syslog_message}" }
    output {
    if [type] == "syslog" and "_grokparsefailure" in [tags] {
    file { path => "/tmp/failed_syslog_events-%{+YYYY-MM-dd}" }
    else {
    elasticsearch { host => "localhost" }
  • 2.  RE: Clearpass and Elasticsearch, Logstash, and Kibana (ELK)
    Posted Aug 21, 2015 06:16 PM
    I've created a GitHub repository containing my logstash.conf file and the Export of my ClearPass Syslog configuration.  Comments and suggestions welcome!
  • 3.  RE: Clearpass and Elasticsearch, Logstash, and Kibana (ELK)
    Posted Aug 21, 2015 06:32 PM
    Cool always appreciated. I check it out and pass it off to the ClearPass specialists.
