Clearpass and HP Procurve switches integration for 802.1x and wired guest
  • 1.  Clearpass and HP Procurve switches integration for 802.1x and wired guest
    Posted Apr 30, 2017 02:25 PM
    We are deploying clearpass in our network and having below requirement
    We have HPE Procurve 5300,2700 switches and want to integrate with clerpass for 802.1x authentecation with policy condition to check for Corp device and if end device is not part of domain then device should get guest captive portal.
    I didn't find any useful resource on internet also I heard that there are issue with COA too. Please help me to integrate the same.
  • 2.  RE: Clearpass and HP Procurve switches integration for 802.1x and wired guest
    Posted Apr 30, 2017 02:27 PM
    Please provide the exact model and code versions.
  • 3.  RE: Clearpass and HP Procurve switches integration for 802.1x and wired guest
    Posted Apr 30, 2017 02:38 PM
    Hi Cappalli,
    Thanks for immediate response.
    HP Procurve 5304xl and 2724(15.16.0011) software code.
    Also please let me know which software code and HP Procurve switch model support it as i have other series of Procurve switches too.
  • 4.  RE: Clearpass and HP Procurve switches integration for 802.1x and wired guest
    Posted May 01, 2017 10:33 AM
    Those are very old switches. We have only tested ProVision and newer switches. I would reach out to your ClearPass partner.
  • 5.  RE: Clearpass and HP Procurve switches integration for 802.1x and wired guest
    Posted May 01, 2017 11:51 AM
    Will 802.1x working on those switches ?
  • 6.  RE: Clearpass and HP Procurve switches integration for 802.1x and wired guest
    Posted May 01, 2017 11:55 AM
    I would assume so just because 802.1X is usually pretty standard, but honestly, I’ve never even heard of these models before.
  • 7.  RE: Clearpass and HP Procurve switches integration for 802.1x and wired guest
    Posted May 01, 2017 12:53 PM
    It's 2700 and 5300 series switches. Can you give me procurve switch and software code list which fulfill my requirement.
