ClearPass and Instant APs
  • 1.  ClearPass and Instant APs
    Posted Jun 27, 2012 03:09 AM
    Does ClearPass integrate with Instant APs, in the same way as campus APs?  In order to use an external captive portal for guest networks, does this require the Guest module for Clearpass?
    Are we able to use onboarding from ClearPass with the Instants?
  • 2.  RE: ClearPass and Instant APs
    Posted Jul 02, 2012 11:40 PM
    Yes, Instant guest SSID can integrate with the external captive portal functions of ClearPass Guest.
    Onboarding will also be supported assuming you have configured an Onboard provisioning link from your guest captive portal configuration. The current release of Instant does allow captive portal on enterprise (802.1x) SSID's.
    Hope this helps
    Cam
