Couple questions in the regards of CPPM and Intune extension.
Sysinfo: CPPM 6.7.9, cluster of two nodes. Using intune extension v4.0.0.
1) Any special considerations needed when deploying in a cluster?
For now I ran all commands following the latest guides on the publisher, I assume this is the way, but a bit unsure in terms of the extension IP.
2) Having the extension installed and added as an authorization source for the standard 802.1x CPPM service causes logins every so often to timeout.
Access tracker reveals:
Failed to get value for attributes=[OS Family].
Session failed for Host=http://172.17.0.2, Reason=[get::<easy_perform>, (error=56) Failure when receiving data from the peer].
[MS Intune Auth Source] - authorization took 30 secs
Whenever the timeout doesn't happen I can see the gathered intune attributes.
