Hi guys,
I've similar problem with a CP 6.7 and FortiWLC 8.4.1 build 1 (Meru).
The procedure written on the document doesn't work for me with the specified versions of CP and FortiWLC.
When I try to setup ont the FortiWLC the internal Captive portal with the customized pages, specified on the PDF, I get a redirect loop.
I had to setup the FortiWLC with an external captive portal.
The redirection to CPass Guest works fine.
Also the authentication works fine when the Clearpass call back the FortiWLC after the user registration with the submit URL http://<FortiWLC_IP_or_URL>:8082/vpn/loginUser
The real problem is that the client seems to stuck on a FortiWLC blank page after the authentication (http://FortiWLC:8082/vpn/loginUser).
It' similar to the problem decribed on this page:
https://community.arubanetworks.com/t5/Security/Meru-ClearPass-Guest/td-p/184950
I would like to pass a fixed URL to the FortiWLC to redirect the client after authentication.
I've tryed to force the url on the HTTP POST url, and with the CPass forcing but it doesn't work (or I cannot find the right variable)
On the FortiWLC there is no way to force a rediretion URL after authentication.
Do you have any suggestions?
dave_m have you find a solution to the problem?
