I set Clearpass and Palo Alto for communication via API
( follow this instruction http://www.arubanetworks.com/assets/pso/TechNote_ArubaAndPaloAltoNetworksIntegration.pdf )
Now, On palo-alto, It can see only ip-address and username of authenticated clients and didn't see device name or device type. But on clearpass, I see all endpoint informations.
How i troubleshoot and solve this problem ?
Please be sure to use the TechNotes from the support site.
https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=14554
Follow the examples in this guide: ClearPass 6.X and PANW Integration V5. Syntax has changed in more recent versions of ClearPass.
Following page 20, There isn't IP-Address-Change-Notification on session-type
What version of ClearPass are you running? The configuration changed in 6.5 and is documented in the technote.
Well I write the CPPM/PANW TechNote and in the latest published version, V5 [which was published in May 2015] it details on page 19 the required configuration. Here is a link to my TechNote. HTH.
