last person joined: 3 hours ago
Clearpass and Slack - File contains invalid XML tags.
  • 1.  Clearpass and Slack - File contains invalid XML tags.
    Posted May 28, 2018 06:50 AM
    Hey
    Trying to use the xml file for "Endpoint Context Servers" from github.
    Filename is: clearpass-exchange_slack_ecs-csa.xml
    When importing this to version:  6.7.3.106273 is fails with the error message:
     File contains invalid XML tags. Try export to see the valid XML tags.
     Can I fix this somehow ?
    Thanx
    Attachment(s)
  • 2.  RE: Clearpass and Slack - File contains invalid XML tags.
    Posted May 28, 2018 07:22 AM
    Tried both removing and pasting in a current Tipsheader line. Did not resolve the problem.
    Tested it with 6.6.0.81015 wich I have running on the side, and it imported without problems.
    Maybe I will just create the config manually.
    Read this, but not certain it has something to do with it:
    Users should be aware that context server actions that were defined prior to ClearPass 6.7.0 cannot be imported to a 6.7.x version by using the Endpoint Context Servers list’s Import or Export options, nor by any other import action that includes context server actions (for example, from Services with context server actions included).
  • 3.  RE: Clearpass and Slack - File contains invalid XML tags.
    Posted Jun 04, 2018 05:53 AM
    I recreated this manually. Now its working.
