Clearpass API PATCH delete attributes
  • 1.  Clearpass API PATCH delete attributes
    Posted May 31, 2022 08:09 AM
    I've had a bit of a search on this but couldn't find anything other than an example for the XML API, where setting attribute value to an empty string would apparently delete it (How to delete/modify an endpoint attribute using tips API? (arubanetworks.com)).
    Trying to achieve this with a PATCH request in the new?/json?/not sure what the differentiating name is? API.
    Setting an existing attribute to null isn't supported, setting to an empty string leaves it defined as an empty string (and still included in a GET with filter {"MyAttribute": {"$exists":true}} )
    In my case I want to delete custom attributes from an Endpoint, but would expect the action to be the same for other objects.
    Does anyone have other suggestions?
    Derek Smith
