ClearPass API - Get Endpoint lists and filter based on endpoint attributes
  • 1.  ClearPass API - Get Endpoint lists and filter based on endpoint attributes
    Posted Dec 10, 2017 05:12 AM
    Hello community,
    I'm playing around with ClearPass API Explorer, and what I'm trying to do is to get a list of endpoints in my endpoint repository, and filter the result using endpoint attributes. The sample data for an endpoint looks like this:
    "_embedded": {
        "items": [
            "id": 3004,
            "mac_address": "f822934bb108",
            "status": "Known",
            "attributes": {
              "Owner": "user1@example.com",
              "social_vip": "",
              "Device IMEI": "01 374800 460669 4",
              "Device Name": "iOS",
              "Device Type": "iOS",
              "Device UDID": "50e082617c1c07c25dd12706b79be6a",
              "Product Name": "iPhone6,1",
              "social_roles": "[]",
              "social_groups": "[]",
              "social_userType": "Member",
              "social_username": "user1@example.com",
              "social_timestamp": "1512108128",
              "social_objectType": "User"
    I can filter the result based on an endpoint's MAC address by specifying this syntax in the filter box:
    {"mac_address": "<mac address>"}
    But when I tried to filter based on associated attributes of an endpoint using this syntax:
    {"attributes": {"social_username": "user1@example.com"}}
    it failed, and the API Explorer responded with code 422 which said invalid filter expression. So I know my filter syntax for endpoint attributes was not correct, but how should I configure it then?
    Thank you,
  • 2.  RE: ClearPass API - Get Endpoint lists and filter based on endpoint attributes
    Posted Dec 10, 2017 10:58 AM
    You cannot filter on attributes today.
  • 3.  RE: ClearPass API - Get Endpoint lists and filter based on endpoint attributes
    Posted Dec 10, 2017 10:50 PM
    Thanks Tim for your quick reply. I'll try a different solution then.
  • 4.  RE: ClearPass API - Get Endpoint lists and filter based on endpoint attributes
    Posted May 17, 2018 04:00 AM
    For me, fetching half a million endpoint records and filtering afterwards is not an option. Filtering on attributes is a really basic and important feature. I hope this implementaiton will find it's way into a future version of the API.
    Also, @Zaffiro what alternate solution did you come up with?
  • 5.  RE: ClearPass API - Get Endpoint lists and filter based on endpoint attributes
    Posted May 17, 2018 10:51 AM
    Hi Mart,
    Previously I had a requirement  to get a list of endpoints belong to a certain user. My first thought was to filter based on the social_username attribute associated with an endpoint. But as you can see it failed. So my alternate solution back then was to get all the user certificates based on subject_common_name attribute, and extract the mac addresses embedded inside those certs.
    But I believe starting from version 6.7.0, ClearPass API has support for endpoint attributes filtering. I tried {"social_username": "user1@example.com"} and it worked (notice there's no "attributes" keyword in the filter syntax). I think you should try again and see if it works for your case.
  • 6.  RE: ClearPass API - Get Endpoint lists and filter based on endpoint attributes
    Posted May 17, 2018 03:56 AM
    I understand that filtering on specific attributes is not supported, but is it possible to filter if an Endpoint holds any attributes at all?
    I tried several filter expressions, amongst them :
    {"attributes":{"$exists":true}}
    without success.
  • 7.  RE: ClearPass API - Get Endpoint lists and filter based on endpoint attributes
    MVP
    Posted Mar 12, 2019 04:05 PM
    When is that support ecpected?
  • 8.  RE: ClearPass API - Get Endpoint lists and filter based on endpoint attributes
    Posted Jun 13, 2019 09:35 AM
    This was added in CPPM 6.7.2
