Clearpass API Read/Write Device Groups
  • 1.  Clearpass API Read/Write Device Groups
    Posted Feb 16, 2017 01:14 PM
    I'm looking for the correct syntax to read the contents of a Clearpass Device Group as well as add a member to an existing group via the API. I have successfully setup API calls to read and write endpoints, but I'm not sure the syntax for Device Groups. Thanks!
  • 2.  RE: Clearpass API Read/Write Device Groups
    Posted Feb 16, 2017 01:37 PM
    Get all device groups:
    GET https://{{ClearPass-Base-URL}}/api/network-device-group
    Get single device group:
    GET https://{{ClearPass-Base-URL}}/api/network-device-group/{{device-group-id}}
    Add device to device group:
    PATCH https://{{ClearPass-Base-URL}}/api/network-device-group/{{device-group-id}}
    "value": "100.81.0.11"
    NOTE. This will override the field, so if you are adding a value, you need suck in the old values, and append the new one.
  • 3.  RE: Clearpass API Read/Write Device Groups
    Posted Feb 16, 2017 02:06 PM
    Thank you - that pointed me in the right direction. The API URL is actually https://{clearpass-server}/tipsapi/config/read/NadGroup.
    I was then able to build the XML and apply a filter criteria to get the specific groups I need. Should be relatively simple to build the XML to append to that list and write back to Clearpass. Thanks!
  • 4.  RE: Clearpass API Read/Write Device Groups
    Posted Feb 16, 2017 02:16 PM
    That's the legacy SOAP API. You should use the new RESTful API which is what I posted.
  • 5.  RE: Clearpass API Read/Write Device Groups
    Posted Feb 16, 2017 02:21 PM
    Ok, thanks - hadn't realized the API was updated.
    Can you point me in the direction of documentation? I tried the URL you sent and it did not work - is there a minimum version for REST API support?
  • 6.  RE: Clearpass API Read/Write Device Groups
    Posted Feb 16, 2017 02:23 PM
  • 7.  RE: Clearpass API Read/Write Device Groups
    Posted Feb 16, 2017 02:26 PM
    Thanks again, Tim - I'm getting 403 forbidden errors attemptin to just use the API explorer. Shouldn't the base HTTP authentication work for this purpose?
  • 8.  RE: Clearpass API Read/Write Device Groups
    Posted Feb 16, 2017 02:29 PM
    Are you using a browser? It will redirect you to login.
  • 9.  RE: Clearpass API Read/Write Device Groups
    Posted Feb 16, 2017 02:31 PM
    Yes - the redirect occurred and I logged in, but now I'm getting 403 errors using the API explorer. I encountered this issue in the past which had me resorting to the SOAP API.
  • 10.  RE: Clearpass API Read/Write Device Groups
    Posted Feb 16, 2017 02:32 PM
    Screenshot please.
  • 11.  RE: Clearpass API Read/Write Device Groups
    Screenshot please.
  • 12.  RE: Clearpass API Read/Write Device Groups
    Posted Feb 16, 2017 02:39 PM
    Screenshot of the API explorer above. When I navigate to /api-docs, I'm redirected to Clearpass Guest to login, which is successful and then I'm redirected back to the /api-docs URL where I select NetworkDeviceGroup and try the GET method. Screenshot it the result.
  • 13.  RE: Clearpass API Read/Write Device Groups
    Posted Feb 16, 2017 02:44 PM
    Did you create an API client and access token? Take a look at that doc. It
    goes over everything.
  • 14.  RE: Clearpass API Read/Write Device Groups
