Clearpass Auth type not set
  • 1.  Clearpass Auth type not set
    Posted Dec 06, 2013 03:59 AM
    Hi all,
    I have a service on clearpass that is working with a number of instant AP sites and a controller-based site in another continent. I am in the process of moving the UK controller to use the same service. The PEAP user authentications are throwing up the error - " rlm_auth_check: Auth-Type not set or authentication methods have not been configured". The devices across the company should all be using the same settings, so I believe the client base should be the same. When I add [mschap] to the list of authentication methods in clearpass the authentications in the UK are successful. Its a new test profile on the controller that I am using - any ideas why the required EAP-PEAP is not working?
    Matt
  • 2.  RE: Clearpass Auth type not set
    Posted Dec 06, 2013 06:55 AM
    @matt Finnie wrote:
    Hi all,
    Matt
    Not enough information to make a determination.  Has the incoming authentication been classified by a service?
  • 3.  RE: Clearpass Auth type not set
    Posted Dec 06, 2013 07:52 AM
    Yes the request correctly matched the required service - as I said it works if I add in [MSCHAP] into the authentication methods.
  • 4.  RE: Clearpass Auth type not set
    Posted Dec 06, 2013 08:06 AM
    If it works with PEAP, you should look at the successful authentication and see the radius attributes, and determine from there.  That is where the answer is.
  • 5.  RE: Clearpass Auth type not set
    Posted Dec 06, 2013 08:28 AM
    The failure scenario shows this -
    Policies Used -
     Service: XXXX PEAP UK user 802.1X Service
     Authentication Method:
     Authentication Source: AD:cor-str-XXXX.corp.XXXX.com
     Authorization Source:
     Roles: Unauthorized Device
     Enforcement Profiles: [Deny Access Profile]
     Service Monitor Mode: Disabled
    Input RADIUS Attributes -
     Radius:Aruba:Aruba-AP-Group = test-cppm-switch
     Radius:Aruba:Aruba-Essid-Name = XXXX
     Radius:Aruba:Aruba-Location-Id = 0-test-6c:f3:7f:ce:3d:b2
     Radius:IETF:Called-Station-Id = 000B860F6780
     Radius:IETF:Calling-Station-Id = 100BA9BEB268
     Radius:IETF:NAS-IP-Address = 10.XXXX.XXXX.XXXX
     Radius:IETF:NAS-Port = 0
     Radius:IETF:NAS-Port-Type = 19
     Radius:IETF:Service-Type = 1
     Radius:IETF:User-Name = CORP\\XXXX
     Radius:Microsoft:MS-CHAP2-Response = 0x08000a2766406e4c4c8ac4cd435414f0a5d8000000000000000065090d46f72472d8456d50d963ac8b8549ac1b2e9bfc0e36
     Radius:Microsoft:MS-CHAP-Challenge = 0x3b1e5c2483878520f1631ff6af2b1fa4
    When I add [MSCHAP] as an authentication method -
    Policies Used -
     Authentication Method: MSCHAP
     Authorization Source: [Endpoints Repository], XXXX CORP Active Directory
     Roles: [User Authenticated], peap-user
     Enforcement Profiles: [Allow Access Profile]
     Radius:Microsoft:MS-CHAP2-Response = 0x0800f85b569fe9eba7ec78c72e4f7f7f927700000000000000001f8008bc2fb94407a048623a04404c4a9a64fb8ed8a81553
     Radius:Microsoft:MS-CHAP2-Success = 0x08533d31383144393033423041433937444646343737344634434534423341343539414537414146314634
     Radius:Microsoft:MS-CHAP-Challenge = 0x6bbe39c0e77210d1ec59de9e77e80a6d
     Radius:Microsoft:MS-MPPE-Encryption-Policy = 0x00000001
     Radius:Microsoft:MS-MPPE-Encryption-Types = 0x00000006
     Radius:Microsoft:MS-MPPE-Recv-Key = 0xff6e517a08df8344fbba4c907071d2fa
     Radius:Microsoft:MS-MPPE-Send-Key = 0xca7459743b6c39b2389e04d9d7b1ea70
  • 6.  RE: Clearpass Auth type not set
    Posted Dec 06, 2013 09:26 AM
    Is that controller by chance terminating the EAP session and only sending over the inner MSCHAP authentication portion; rather than the entire EAP session?  Check the dot1x profile for that configuration to see if EAP termination is on.
  • 7.  RE: Clearpass Auth type not set
    Posted Dec 07, 2013 09:16 AM
    I did not believe that it was, but in fact it is. I have created a new dot1x profile without termination enabled and customer tells me that it is working. Thanks for that. Can someone explain why the authentications were hitting Clearpass - does the controller only terminate certain EAP types and backoff the rest?
  • 8.  RE: Clearpass Auth type not set
    Posted Dec 07, 2013 12:54 PM
    If you have termination enabled, it will use work with the eap types that are selected in the same dot1x profile.    All the controller does is terminate the tunnel, the authentications are still passed onto the server defined in the AAA profile server group.  If you had termination enabled and CPPM as the server group, the controller would terminate the connection from the client and then pass auths to CPPM.  They probably matched all the conditions of the service.....however they were no longer PEAP authentications, so they would fail (unless you enabled MSCHAP as an authentication type on the service.
  • 9.  RE: Clearpass Auth type not set
    Posted Dec 07, 2013 05:02 PM
    Thanks for the help and the explanation.
