last person joined: 11 hours ago
ClearPass Authentication failure Error 204
  • 1.  ClearPass Authentication failure Error 204
    Posted Dec 02, 2017 06:25 AM
    i have to configure guest wifi access with ClearPass Captive portal.
    i have configured 2 VLANs(internal corporate and guest), made SSIDs. and i have working internal WLAN and Guest internet.
    I used this link for confiruration of captive portal.
    http://community.arubanetworks.com/t5/AAA-NAC-Guest-Access-BYOD/How-to-integrate-Aruba-Controller-with-CPPM-to-perform-Captive/ta-p/192291
    After i connect my device to wifi AP it forward me to IP addess of clearpass guest portal. I fill in the user name and email and after clicking login it forward me back to registration page.
    At the access tracker I see that i have "no service match and error 204".
    I have configured only one service - Controller Guest Service Guest Access.
    Please help. How to configure correctly captive portal authentication?
  • 2.  RE: ClearPass Authentication failure Error 204
    Posted Dec 02, 2017 09:57 AM
    Look in the service rules for the service and see which value is not matching.
  • 3.  RE: ClearPass Authentication failure Error 204
    Posted Dec 02, 2017 01:18 PM
    in the service rules i found 3 rules.
    the third seems was created when I added the service..
    i don't know what to fix here... SSID is ok. Radius authentication is also..
  • 4.  RE: ClearPass Authentication failure Error 204
    Posted Dec 04, 2017 06:45 AM
    • Have you mapped proper authentication source in service rule?
    • Are you using posting https or http request? If you dont have proper CA certiifcate installed , try disable https option in guest page
    • Do you have CA certificate intalled on controller/CPPM?
    Pavan
