The ClearPass is likely joined to the domain, and if you don't see it in AD, your AD admin probably deleted the computer account and that results in the logs you shared.
Then also it's logical that if you power off the ClearPass server that the messages disappear. If you want to use the ClearPass server, go in Administration -> Server Configuration -> select your appliance -> Use the Leave Domain button to remove the domain membership of ClearPass:
![](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/7f1ffd3356cc4d18ab3126da338a771d.png)
If you use PEAP authentication against your AD, that is likely to fail, but it's supposed to be failing already if the account in AD has been removed.
Please work with your local Aruba partner as they may be able to explain all better than I can; they probably know your deployment as well.
Original Message:
Sent: Jan 26, 2023 08:58 PM
Subject: Clearpass authentication logs
the username and remote device actually refers to my clearpass server hostname.
it is currently not in my AD, either as username or computer name.
i can only see the hostname in my DNS server.
the logging has since stopped since i power down the clearpass server for 12 hrs last thursday.
Original Message:
Sent: Jan 26, 2023 11:06 AM
That is the computer account that is created during the 'join domain' of your ClearPass server.
It may be that someone disabled or deleted the account, and if you don't do PEAP authentication, you can leave the ClearPass from the domain
Original Message:
Sent: Jan 18, 2023 01:06 AM
We have syslog logging for our clearpass server.
Recently we noticed that there is alot of errors from clearpass
how do i check who/what devices are causing this?
Our AP are now under Aruba Central, there is no on-premise controller.
