it works for me, start small, like for past 24 hours and just before that create some roles. so that you'll have some data.
This is my report.
then when i run the report , get this
Original Message:
Sent: Jul 07, 2022 02:49 AM
Subject: ClearPass Automated Report of Audit Viewer
Hi Ariyap,
Thanks for your reply and screenshot. I've setup the System > Configuration report but once I generate a report, the report doesn't show any data. Here's my setup:
Inside the generated PDF:
What am I missing?
Lex
Original Message:
Sent: Jul 06, 2022 07:32 PM
here is a screenshot for it.
you login to Insight and then choose reports -> Create New Report
Original Message:
Sent: Jul 06, 2022 03:00 PM
Check out ClearPass Insight for this. You can configure reports to be sent (Insight must be enabled on your ClearPass cluster). Also Aruba recommends if you need more than 7 days of retention time to setup an external log collector.
Original Message:
Sent: Jul 06, 2022 02:58 AM
Hi all,
Is it possible to generate an automated report of the Audit Viewer contents? In the webinterface of ClearPass Policy Manager I can only view back 7 days of changes in the Audit Viewer. I would like to automatically save/report this data.
Thanks in advance!
Lex
