Clearpass between two sites with vpn site to site connection
  • 1.  Clearpass between two sites with vpn site to site connection
    Posted Oct 12, 2017 09:39 AM
    Hi Community:
    Anybody knows if it's possible to configure the Clearpass when I have a vpn connection between the sites.
    e.g:
    I have the CPPM instaled  at main office, so in the branch I want to autenticate the guest users with the CPPM.
    The question is: How can I do it ?
    The vpn connection is between Cisco Meraki.
    The access points are IAP-315 (instant solution)
    Thanks in advance.
    Regards
  • 2.  RE: Clearpass between two sites with vpn site to site connection
    Posted Oct 12, 2017 09:42 AM
    Yes. As long as the IAP VC can reach ClearPass, then you can authenticate users.
  • 3.  RE: Clearpass between two sites with vpn site to site connection
    Posted Oct 12, 2017 09:50 AM
    Thanks for your help.
    Yes, VC can reach Clearpass. I can ping from VC to Clearpass.
    At main Office is working fine, but when I try to connect to guest SSID the portal isn't working.
    So, What else I need to configure?
    the dhcp server is provide it by the cisco meraki at branch.
  • 4.  RE: Clearpass between two sites with vpn site to site connection
    Posted Oct 12, 2017 09:57 AM
    Did you configure all of the required captive portal options on the IAP?
  • 5.  RE: Clearpass between two sites with vpn site to site connection
    Posted Oct 12, 2017 10:03 AM
    Yes. all field required.
