Clearpass blacklisted users
  • 1.  Clearpass blacklisted users
    Posted Mar 26, 2017 09:18 AM
    I applying an enforcement profiles that blacklist any user when daily bandwidth limit is exceeded.
    The Clearpass is configure to purge all blacklisted users at midnight
    Everything working fine
    How do I exclude the implementation of this enforcement profile on a specific users and keep it applied on all other users?
    Best Regards
  • 2.  RE: Clearpass blacklisted users
    Posted Mar 26, 2017 09:31 AM
    What type of authentication are you using ?
    Get Outlook for iOS
  • 3.  RE: Clearpass blacklisted users
    Posted Mar 26, 2017 09:34 AM
    AD  &  MAC
    Best Regards
  • 4.  RE: Clearpass blacklisted users
    Posted Mar 26, 2017 12:57 PM
    If is based on a certain type of user can you can leverage AD memberships to determine who or not will be blacklisted
    Get Outlook for iOS
  • 5.  RE: Clearpass blacklisted users
    Posted Mar 26, 2017 04:47 PM
    Dear Victor
    You mean that we can created an enforcement Policies for a specific AD-Group members ?
    Best Regards
  • 6.  RE: Clearpass blacklisted users
    Posted Mar 27, 2017 12:36 PM
    Yes
    Get Outlook for iOS
  • 7.  RE: Clearpass blacklisted users
    Posted Mar 29, 2017 05:22 AM
    Dear Victor
    thanyou ...its working
    but how can manually synchronize Active Directory users with the Clear-Path
    Best Regards
  • 8.  RE: Clearpass blacklisted users
    Posted Mar 29, 2017 09:38 AM
    What are you trying to synchronize? Please clarify.
  • 9.  RE: Clearpass blacklisted users
    Posted Mar 30, 2017 04:09 AM
    Dears
    I create AD Group ( wireless_No_blacklist )  and i create an enforcement condition to give allow access to ( Wireless_No_blacklist ) members
    check out the attached Pic.
    the problem is: when i assign a new AD user to (Wireless_No_blacklist ) it takes many hours to appear on clears Pass so is there any way to sync the new users manually
    Best Regards
  • 10.  RE: Clearpass blacklisted users
    Posted Mar 30, 2017 06:10 AM
    You can either do a clear cache manually under sources > your ad
    Or decrease the cache value
    Noté: be careful decreasing the value because that means that clearpass will contact the AD more often
    Get Outlook for iOS
  • 11.  RE: Clearpass blacklisted users
    Posted Mar 30, 2017 06:20 AM
    Dear Victor
    I appreciate your great help
    thank you
