ClearPass CA - 802.1x EAP-TLS
  • 1.  ClearPass CA - 802.1x EAP-TLS
    Posted Mar 01, 2018 08:25 AM
    I need to use ClearPass as a Certification Authority for 802.1x (EAP-TLS). Is it possible to use it that way ? And will I need an OnBoard licences for that CA ?
    Vaclav
  • 2.  RE: ClearPass CA - 802.1x EAP-TLS
    Posted Mar 01, 2018 08:28 AM
    Yes, Onboard is the ClearPass feature for issuing unique device < > user identities using certificates and EAP-TLS.
  • 3.  RE: ClearPass CA - 802.1x EAP-TLS
    Posted Mar 01, 2018 08:32 AM
    Yes, you'll need the OnBoard license to enable this feature; but it will do just what you want.
  • 4.  RE: ClearPass CA - 802.1x EAP-TLS
    Posted Mar 01, 2018 08:36 AM
    Thank you guys. Is there any cookbook for that use? I'm familiar with MS AD Cert. Authority with AutoEnrollment but customer wants to use ClearPass as CA.
    Vaclav
  • 5.  RE: ClearPass CA - 802.1x EAP-TLS
    Posted Mar 01, 2018 08:39 AM
    Everything is covered in the user guide, but you can always reach out to your ClearPass partner if you need additional deployment assistance and best practice design guidance.
  • 6.  RE: ClearPass CA - 802.1x EAP-TLS
    Posted Mar 01, 2018 05:27 PM
    ABC Networking on YouTube also has a good video series on setting up Onboard
    #AirheadsMobile
