Clearpass CA issue
  • 1.  Clearpass CA issue
    Posted Mar 13, 2017 05:31 AM
    I configure clearpass as root CA for onboard device provisioning. I install certificate on IOS device but I try to show certificate view by device or username. There're not any records What is my fault?
    Thank you
  • 2.  RE: Clearpass CA issue
    Posted Mar 13, 2017 07:28 AM
    Screenshot please.
  • 3.  RE: Clearpass CA issue
    Posted Mar 14, 2017 04:39 AM
    After user authentication is successful.
    It hits BYOD-Provision service and user will get provision role
    On controller side, I set rule as captive portal. Page will be redirect to provision device portal. I enter username and password. Authentication is successful. User hit BYOD-Pre  auth service. no any radiusattribute return to user because I used default profile.
  • 4.  RE: Clearpass CA issue
    Posted Mar 14, 2017 12:17 PM
    The Onboard Pre-Auth service should generally always send an Allow Access. Are you able to get past the Onboard login?
