I have a captive portal which is using user credentials from an AD auth source an failing. The user is being successfully found during the lookup, followed by these errors:
Access Tracker:
I would have though one of these methods would be used. I've tried lots of combinations.
Event Viewer:
Failed to decode RADIUS packet - Received packet from 10.22.0.8 with invalid Message-Authenticator! (Shared secret may be incorrect.) - I've verified the secret is correct.
Does the message in the event viewer above relate to the reject in the pcap highlighted below?
