ClearPass Captive Portal Wired SSL_PROTOCOL_ERROR
This thread has been viewed 51 times
  • 1.  ClearPass Captive Portal Wired SSL_PROTOCOL_ERROR
    MVP
    Posted Sep 03, 2021 03:40 AM
    Hi everybody,
    I´m trying to implement a guest access captive portal redirect. I´ve setup everything on my switch and in clearpass. The redirect is working, but the captive portal page fails to load with: ERR_SSL_PROTOCOL_ERROR
    I´ve already impelemented captive portal for wireless and there everything is working fine.
    I´ve duplicated the self registration page, which is use for wireless, changed "Name" and "Register Page". Am I missing something?
    Matthias Pohl
  • 2.  RE: ClearPass Captive Portal Wired SSL_PROTOCOL_ERROR
    MVP
    Posted Sep 03, 2021 06:54 AM
    Okay, I missed to install the certificate on the switch.
    But now I stuck at:
    Connect to a network
    The network you´re using may require you to go to its sign-in page.
    Matthias Pohl
  • 3.  RE: ClearPass Captive Portal Wired SSL_PROTOCOL_ERROR
    Posted Sep 03, 2021 09:45 AM
    What type of switch?
    Can you connect to the ClearPass when the switch is showing the captive portal (ClearPass should be exempted from redirection)?
    What is showing that message? Can you see a URL? Can you reach that URL manually?
    Maybe easiest to find someone to have a look together in the live environment. There are some wired guest videos on the Airheads Broadcasting Channel for AOS Switch and AOS CX as well.
  • 4.  RE: ClearPass Captive Portal Wired SSL_PROTOCOL_ERROR
    MVP
    Posted Sep 03, 2021 10:20 AM
    Hi Herman,
    I´ve tested with an Aruba 2530 and an Aruba 2540.
    The client is redirect to the Selfregistration page, but the page isn´t loaded. Just showing (in the browser):
    I will check the videos for AOS switch
    Matthias Pohl
  • 5.  RE: ClearPass Captive Portal Wired SSL_PROTOCOL_ERROR
    Posted Sep 03, 2021 10:46 AM
    Did you create a rule to allow traffic to ClearPass through your captive portal? From what you describe, it may be that the client is redirected when it tries to go to ClearPass as well.
  • 6.  RE: ClearPass Captive Portal Wired SSL_PROTOCOL_ERROR
    MVP
    Posted Sep 17, 2021 07:47 AM
    Hi Herman,
    I´ve used the wrong CPPM IP. Changing the IP to the DataPort-IP, the redirection to the Selfregistration-Page works fine.
    But now I stuck at the next problem. I was able to register a new guest account, but when I try to login with my guest account, I get redirected to the selfregistration page again...
    Matthias Pohl
  • 7.  RE: ClearPass Captive Portal Wired SSL_PROTOCOL_ERROR
    Posted Sep 17, 2021 02:43 PM
    Hi Matthias,
    As you are working with CP, I assume you have already change the vendor setting to "Server Initiated" under the Guest Registration page.
    And CoA is already set up along with a WebAuth + MAC Auth service.
    If the above is done, do you see a WebAuth request on Access Tracker when you log in? If you do see it then are we getting a successful CoA ( we should see one more MAC auth after WebAuth ) which will change the role to post else you would be redirected back to the login page.
    Here either you could refer to the Wired Policy Guide (https://support.hpe.com/hpesc/public/docDisplay?docId=a00091135en_us) or you could raise a TAC case to review the config
    SANDEEP YADAV
    Global Escalation Center, ACCP | Aruba Software
  • 8.  RE: ClearPass Captive Portal Wired SSL_PROTOCOL_ERROR
    MVP
    Posted Sep 18, 2021 02:05 PM
    Hi Sandeep,
    first I see the MACAuth on Access Tracker (Username=MAC). Then I get redirected to the GuestRegistration page. Then I move to the Sign In Page (I´ve already registered a new account). I enter user and password and see a WebAuth on AccessTracker (Username=eMail), but then I get redirected to the GuestRegistration Page.
    I tried to adopt the Wired Policy Guide to me needs...
    Kind regards
    Matthias
    Matthias Pohl
  • 9.  RE: ClearPass Captive Portal Wired SSL_PROTOCOL_ERROR
    Posted Sep 19, 2021 10:24 AM
    Hi Matthias,
    Alright so the only pending part is the CoA, do you see a CoA tab on the First MAC Auth Request? and is it successful or failed?
    Also, even if the CoA is failing, if you disconnect and connect back into the network do you have full access to the network or it still redirects back to the portal page?
    For the CoA test, you could open the MAC Auth request on Access Tracker and try triggering CoA from there.
    SANDEEP YADAV
  • 10.  RE: ClearPass Captive Portal Wired SSL_PROTOCOL_ERROR
    MVP
    Posted Sep 19, 2021 01:23 PM
    Hi Sandeep,
    I don´t see a CoA tob on the first MAC auth request. If I disconnect and connect back, i´m redirected to the portal page.
    I tried to trigger a CoA from the AccessTracker, but it fails (no response from device). I´ve checked the firewall and I see port 3799 (Radius Dynauth) is blocked (source CPPM destination: Switch). I´ll have to check with the firewall team, I have only read-only access to the firewall...
    Matthias Pohl
  • 11.  RE: ClearPass Captive Portal Wired SSL_PROTOCOL_ERROR
    Posted Sep 20, 2021 03:47 AM
    Matthias,
    It's really hard to see what is going wrong. It may be best to work with your partner or Aruba support to troubleshoot the steps.
    How the steps should work for ArubaOS wired external captive portal/service initiated workflow:
    - Client enters the network, a MAC authentication goes to ClearPass and ClearPass returns a role/attributes to redirect the client to the ClearPass captive portal
    - Client redirects to ClearPass captive portal
    - User registers/signs in
    - ClearPass authenticates the user (webauth), updates endpoint database, triggers CoA port bounce
    - Client is disconnected, and reconnected, switch will send another MAC authentication.
    - ClearPass will return normal access role based on cached roles or endpoint database attributes.
    There should be no certificate warnings anywhere in this process, and the switch does not need a certificate. Just ClearPass needs trusted certificates.
