ClearPass Captive Portal with auto login
  • 1.  ClearPass Captive Portal with auto login
    Posted Nov 04, 2014 10:58 AM
    It has been awhile since I have been under the hood in Clearpass.  I have a functioning captive portal that requires an email address or phone number.  Once entered, the user is sent a password via email or sms.  They then have to login on other page with the password.
    I have been asked to remove the need to enter the password.  Is there way to automatically allow access/login after registration without the user entering the password?
    -Kevin
  • 2.  RE: ClearPass Captive Portal with auto login
    Posted Nov 04, 2014 11:10 AM
    You should be able to enable this by enabling the NAS Login option under your self-registration page.
  • 3.  RE: ClearPass Captive Portal with auto login
    Posted Nov 04, 2014 11:17 AM
    clembo,  I already have that enabled in the current setup.
  • 4.  RE: ClearPass Captive Portal with auto login
    Posted Nov 04, 2014 11:22 AM
    When they complete registration, on the receipt page is there not a login button visible?    If not, check your receipt form to see if the field is enabled/visible.
  • 5.  RE: ClearPass Captive Portal with auto login
    Posted Nov 04, 2014 11:35 AM
    The login button is there. Once clicked, it requests the password.
    I would like to remove the requirement to enter the passowrd.  The user supplies an email address or phone number, agrees to the T&C and gets the reciept.  Clicking the login button gives them direct access.
  • 6.  RE: ClearPass Captive Portal with auto login
    Posted Nov 04, 2014 12:14 PM
    Try creating a new page but not a duplicate one
  • 7.  RE: ClearPass Captive Portal with auto login
  • 8.  RE: ClearPass Captive Portal with auto login
    Posted Nov 04, 2014 02:24 PM
    Troy,
    I have set up solution you linked to.  It works but I get a pop message stating "This form is not secure. Are you sure you want to submit it?"
    Any idea?
  • 9.  RE: ClearPass Captive Portal with auto login
    Posted Dec 20, 2014 03:33 PM
    is your page on http or https? might be your mixing both methods currently and your browser warns about that.
