last person joined: 10 hours ago
ClearPass categories of static IP devices
  • 1.  ClearPass categories of static IP devices
    Posted Aug 21, 2018 04:45 AM
    Hi, I have a problem to manually classified some network devices. There are static IP network cameras which are not profiled by DHCP profiller and when I want to Update/Add Fingerprint Network Camera/HikVision/HikVision Camera there is an error: "Device Category/Family/Name combination is invalid."
    Is there any way how to solve that ?
    Vaclav
  • 2.  RE: ClearPass categories of static IP devices
    Posted Aug 21, 2018 05:40 AM
    You can use the Update FingerPrint option  for the device that are already profiled. (For e.g. Devices that are profiled as generic/unknown/etc).
    Subnet scan would help you to profile the static devices in the network.
    Try configuring the subnets under Configuration >> Profile and network Scan.
    You may also try adding the Camers under Guest Devices and allow access using the [Guest Device Repository] as auth source, if the numbers are low.
  • 3.  RE: ClearPass categories of static IP devices
    Posted Aug 22, 2018 02:06 AM
    The combination of Category/Family/Name needs to be in the fingerprint dictionary (Administration » Dictionaries » Fingerprints). If you add the desired combination there, you can select it.
    Check out this video where I show how to create a new combination (and automatically profile devices with DHCP into that category, which is not applicable in your case of static IP).
  • 4.  RE: ClearPass categories of static IP devices
    Posted Aug 22, 2018 06:56 AM
    Hi Herman,
    The combination exists in the dictionary.
    I suspect the error is the result of endpoints/devices not being profiled already in this case (as generic/unknown/<other>).
    Error: "Device Category/Family/Name combination is invalid."
    Btw, nice explanation on Custom Fingerprints :)
